Did you Know the generator dash light, must work or the alt will not work? |
p914 |
Nov 6 2004, 08:00 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
I just had my alternator go out . In addition my dash light didn't work and it is part of the circuit for the charging system to work..
Anybody else heard of this? |
Carlitos Way |
Nov 6 2004, 08:03 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
We had a similar situation with my parents Tempo (their choice, not mine), about 10 years ago. 3 different dealerships looked at it, and it wasn't until we escalated it to Ford's customer service that they finally found the problem... 3 alternators later, within 2 years.
TheCabinetmaker |
Nov 6 2004, 08:07 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
yep, light no work, no charge.
SirAndy |
Nov 6 2004, 08:18 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(vsg914 @ Nov 6 2004, 07:07 PM) yep, light no work, no charge. (IMG:style_emoticons/default/agree.gif) |
Joe Ricard |
Nov 6 2004, 08:24 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Technically the light is required to supply the excitation voltage to the Alt. field winding. You could do it with a resistor but that would be dumb. my 928 had a resistor in parallel to the bulb incase the bulb burned out.
p914 |
Nov 6 2004, 11:25 PM
QUOTE(Joe Ricard @ Nov 6 2004, 06:24 PM) Technically the light is required to supply the excitation voltage to the Alt. field winding. That's what my mechanic said too. He explained the entire process. Funy that a dash light would serve dual function. |
jim_hoyland |
May 21 2016, 08:09 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Rich at WCR: several thread address this. Hope it helps...
Attached image(s) |
timothy_nd28 |
May 21 2016, 08:19 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Replace that light with an LED, and the alternator will quit working too
ssuperflyoldguy |
May 21 2016, 09:56 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
r_towle |
May 21 2016, 10:12 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yes
EdwardBlume |
May 22 2016, 08:13 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
How can you test the connection to the alt gen light? If the light is on and stays on, then its the generator right?
jim_hoyland |
May 22 2016, 08:21 AM
How can you test the connection to the alt gen light? If the light is on and stays on, then its the generator right? Right. When the ignition is turned to on and the light doesn't come on was the problem. The test for this is whether the alt light is getting 12v or not; if there is power and no light then the bulb must be replaced. |
EdwardBlume |
May 22 2016, 08:28 AM
Thanks. I guess I still need to change my alternator.
brant |
May 22 2016, 09:13 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
jim_hoyland |
May 22 2016, 10:09 AM
Question: Is the alt light bulb the same as the oil light bulb ?
Dave_Darling |
May 22 2016, 11:34 AM
Same kind and voltage.
BTW, if the voltage regulator is not plugged in, you won't get an alternator light and the alternator won't charge. Don't ask how I know that... --DD |
jim_hoyland |
May 22 2016, 12:37 PM
Dave_Darling |
May 22 2016, 09:29 PM
Depends on what has gone bad in it.
--DD |
mbseto |
May 23 2016, 11:31 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
worn |
May 23 2016, 11:38 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I just had my alternator go out . In addition my dash light didn't work and it is part of the circuit for the charging system to work.. Anybody else heard of this? Yep. Also you need a two watt bulb or more to get the alternator stated. If you look at the wiring diagram it is one of those clever engineering feats in which the gen light is initially used to bootstrap the windings on the alternator. The way they set it up it warns you of more than one problem using no electronics - just a 2 watt bulb! |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:15 AM |
