WTB: Accelerator cable bracket |
rmital |
Dec 17 2012, 08:29 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
switched to dual 34icts; now attempting to use the original distributor with the vacuum pod....and can't time the car because the bracket is in the way. It hits the pod when turning to time.
what you got??? or any suggestions on where to buy.... Attached image(s) |
SUNAB914 |
Dec 17 2012, 08:47 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
How much clearance do you need? Maybe you can grind some off?
rmital |
Dec 17 2012, 08:54 AM
Gint |
Dec 17 2012, 09:13 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Take the pod off. |
rmital |
Dec 17 2012, 09:40 AM
euro911 |
Dec 17 2012, 10:22 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If installing a new cable mount ('pod'?) in another location isn't an option, you might be think about removing the distributor drive and advance it a tooth or two (as needed), then the condenser will be located further away from the 'pod' which will allow you to adjust the timing several degrees.
IronHillRestorations |
Dec 17 2012, 12:49 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
McMark makes a nice bracket.
rmital |
Dec 17 2012, 01:15 PM
7TPorsh |
Dec 19 2012, 01:26 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I could use one too if available...
McMark |
Dec 21 2012, 01:15 AM
My bracket won't work with this, but I have something that might. Gotta find pics on my work computer.
rmital |
Dec 21 2012, 07:12 AM
ThePaintedMan |
Dec 21 2012, 08:56 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
I've got a bracket that should clear that no problem. I think its the original bracket, but since the car was converted to carbs before I got it, I don't know. Send me a PM. I'll take a picture of it a little bit later and post it. Yours for the cost of shipping.
rmital |
Dec 21 2012, 09:40 AM
I've got a bracket that should clear that no problem. I think its the original bracket, but since the car was converted to carbs before I got it, I don't know. Send me a PM. I'll take a picture of it a little bit later and post it. Yours for the cost of shipping. nice...sending you a PM..... (IMG:style_emoticons/default/piratenanner.gif) |
rmital |
Dec 23 2012, 03:17 PM
ThePaintedMan |
Dec 25 2012, 11:27 AM
Sorry for the delay Ray. Here is a picture.
Attached thumbnail(s) |
rmital |
Dec 25 2012, 12:12 PM
euro911 |
Dec 25 2012, 12:16 PM
Ray, in taking a second look at your exiting bracket, can you grind the lower portion a little to provide the clearance you need for the condenser?
Gint |
Dec 25 2012, 12:19 PM
Take the pod off. was hoping to hook it up to the port on the throttle plate for better advance????? I found the vacuum advance on the last stock distributor I had took 10" of vacuum to turn it. The vacuum port on my Weber 40IDF only pulled 5". So it wasn't doing any good anyway. I put my Mallory on it and never looked back. Check your vacuum source and pod to see if it will even work. |
rmital |
Dec 25 2012, 04:37 PM
Take the pod off. was hoping to hook it up to the port on the throttle plate for better advance????? I found the vacuum advance on the last stock distributor I had took 10" of vacuum to turn it. The vacuum port on my Weber 40IDF only pulled 5". So it wasn't doing any good anyway. I put my Mallory on it and never looked back. Check your vacuum source and pod to see if it will even work. .....will do |
rmital |
Dec 30 2012, 09:50 PM
the bracket from paintedman (George) worked pretty good. had to rearrange my pivot point to the other side of the oil filler. not the best linkage set up, but enough to keep me running. maybe once I'm sure this car will endure and be a decent driver I'll invest more money.... (IMG:style_emoticons/default/flag.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:47 AM |
