jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,186 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
I am going to make a new work bench this winter. Maybe 30" by 16'. 4 by 4's. drawers and a shelf across the bottom. A vise. I am just your typical once-in-while car project and home project type guy.
Don't know what to do for the top. I see places make butcher block. I put formica-type stuff on top of 3/4" plywood one time. I've though about a sheet of metal, but something tells me not to do that. Suggestions? Any other suggestion about a work bench would be appreciated, too. For example, I've thought about getting 2 or 3 half-sized metal shop drawer thinks, bolting them together and putting a work bench top on that. What do you think? |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,590 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
If you want a wood top, try a building supply that may have a damaged solid core wood door. They are heavy enough to support a vise and whatever else you can put on it. I have several in my shop.
two-strokejohn |
Member ![]() ![]() Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States ![]() |
I like metal tops on my workbenches, because they are easier to clean. But, if possible have them made out of light gauge stainless steel.
jfort |
what gauge stainless? how did you hold it down?
mwyatt |
Member ![]() ![]() Group: Members Posts: 84 Joined: 5-April 03 From: San Diego, CA Member No.: 516 Region Association: Southern California ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I have a galvanized steel skin on one of mine. I find it helps for welding. (IMG:style_emoticons/default/welder.gif) The others are just plywood.
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
It depends a lot on what you want to use it for. Gint's solid core door suggestion is a good one, cut to whatever size you need. In addition I usually put a sheet of Duratex/Masonite on top. I tend to beat them up pretty good, and that way it's real easy to just replace the top and start out new again. Down side is if you dump a lot of solvent or carb cleaner out onto your bench. Then it's better to have metal, but I generally don't like the feel of a metal bench. And if you do sheet metal WATCH THOSE EDGES AND CORNERS, they can really fuch you up.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Check your local C/L first. Sometimes it's really cheaper to buy one.
http://sfbay.craigslist.org/eby/fuo/3486125232.html |
abnrdo |
Member ![]() ![]() Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Plywood.
I have made bunches of work benches and tables. I almost always make the top of 3/4 ply. Butcher block looks wonderful, but is kind of a bitch to make, and very expensive to buy. Metal is a double edge sword. Great for a welding bench but I don't like it for general automotive worktop and its bad for wood working. 3/4 ply is my choice but I usually use whatever I have on hand. Which could be two layers of 3/8 or 1/4. For my lathe table I used 2x10 for strength. Zach |
7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
You can but stainless steel flashing for roofs in different thicknesses and sizes. Screw down on top; easy to replace when too stained or dented. Screw down over 3/4" plywood.
URY914 |
Gint's solid core door suggestion is a good one, Yea, great idea Gint! (IMG:style_emoticons/default/sad.gif) |
URY914 |
I also have a bench top made from a hollow metal door. Heavy as hell.
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I was going to sugget the hollow metal door also - Good suggestion Gint ;-);-)
They work good for welding (magnets stick to them), and they are predrilled for hinges. Screw the hinges to the wall, and your work bench can fold flat against the wall. just add folding legs. Stu |
7TPorsh |
I was going to sugget the hollow metal door also - Good suggestion Gint ;-);-) They work good for welding (magnets stick to them), and they are predrilled for hinges. Screw the hinges to the wall, and your work bench can fold flat against the wall. just add folding legs. Stu Not that is a cool idea!!!! |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
I laminated two 3/4 inch sheets of plywood. Routered a groove for a piece of angle iron to protect the edge of the bench. Attached to the studs in the wall and two 2X2 inch tubular steel legs. It's usually a lot more cluttered than it is now. (IMG:style_emoticons/default/laugh.gif)
Cheers, Elliot Attached image(s) ![]() |
OU8AVW |
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region ![]() |
DBCooper |
Gint's solid core door suggestion is a good one, Yea, great idea Gint! (IMG:style_emoticons/default/sad.gif) Sorry, fixed it. And I prove it again, my ex was right, I'm a dumbass. . |
two-strokejohn |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
My main bench is 3 heavy industrial steel doors, I also have two 8 foot benches with 3/4" plywood with a 1/8" gray masonite/melamine top layer.
I just found a formed steel top about the exact size you want....I'm thinking of building a new welding table with it. |
Lo-Fi Version | Time is now: 19th July 2025 - 04:51 AM |
