muffs..er...mufflers, 914-6 part no |
porbmw |
Dec 23 2012, 12:58 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Scrounging around for an OEM muffler for a 6.
Would anyone know the correct part number... And perhaps... Difference between those for a 6....and a taildragger Thanks Paul |
ArtechnikA |
Dec 23 2012, 06:50 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
ETKA says the muffler is 901.111.011.11
The difference is the tailpipe portion, which has a different bend to it. Unless you are using an original valence or participating in national-level concours, either will work fine. Interestingly, the tail pipe portion has its own part number - 901.111.289.00 - but I'd guess there's no chance of finding that separately any more. The chrome tip 'ornamental echaust pipe' is 901.111.245.01 (for completeness). 1969 911 'silencer' is 901.111.025.00 |
porbmw |
Dec 23 2012, 08:52 AM
Wow
That was quick...and complete. Thanks very much Paul |
914Sixer |
Dec 23 2012, 09:07 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You can use a 911 muffler IF you do not have the stock -6 valance. The -6 muffler was bent at the correct angle for the hole in the rear valance.
rgalla9146 |
Dec 23 2012, 10:25 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
You can use a 911 muffler IF you do not have the stock -6 valance. The -6 muffler was bent at the correct angle for the hole in the rear valance. Early OE mufflers had the part number (and production date ) stamped into them. The stamped info is visible at lowest curve of the chamber, nearer the passenger side inlet. Most were Leistritz. The challenge is to find one that is not rusted to illegibility..... or oblivion! Rust free, forty year old muffler ? yeah, no problem. If you are serious about this and need photos or an example for tailpipe shape/orientation I have perfect examples. |
porbmw |
Dec 24 2012, 03:37 PM
Thanks y'all!
I have an original rear valance.... As fate has it, ebay came up with what was advertised as an OEM 6 muffler, never installed, but some surface rust (presumably from storage), esp on one side...it doesn't look that bad from the pics. So I"ve pulled the trigger, thanks to your help re numbers etc. I've never seen one come up, so if this is indeed the real deal, then it's a gift to my original 6... And a thanks again from you. All the best Paul |
Lo-Fi Version | Time is now: 10th June 2024 - 10:49 AM |
