Bursche muffler fitting and shift linkage question |
jdlmodelt |
Dec 23 2012, 10:48 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
I have a 1972 that I just installed the 76 2.0l engine. I have a Bursche muffler system that the previous owner sent home with me. The muffler assemblly won't line up. WHen I first installed the headers they appeared to be hanging too low...so I flipped them over and now the muffler won't fit? Any pics of how it is supposed to look?
Hammy |
Dec 23 2012, 10:55 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
1.7/1.8 and 2.0 exhaust systems are different. Your muffler might be for a 1.7.
jdlmodelt |
Dec 23 2012, 10:59 PM
1.7/1.8 and 2.0 exhaust systems are different. Your muffler might be for a 1.7. Thanks for the insight. The header has a sticker on it that says its for 75 and 76 models. But I wondered if the clearance was different since i was putting a 76 engine/exhaust in a 72 car? |
Hammy |
Dec 23 2012, 11:06 PM
Forgot to mention.. The 75/76 late style headers/heat exchangers were different too, IIRC. They will not bolt up to the earlier style 2.0 mufflers. The 76 2.0 motor will go in your 72 no problem, you just need a matching exhaust/muffler setup. Do you have pictures?
jdlmodelt |
Dec 23 2012, 11:13 PM
Forgot to mention.. The 75/76 late style headers/heat exchangers were different too, IIRC. They will not bolt up to the earlier style 2.0 mufflers. The 76 2.0 motor will go in your 72 no problem, you just need a matching exhaust/muffler setup. Do you have pictures? I'll try to grab some pics tomorrow. thanks, j |
quadracerx |
Dec 24 2012, 10:13 AM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Ok...Im confused...which is nothing new..LOL
So if I had a 76 car the muffler from a 73-74 wont fit without swapping the heat exchangers too? Both cars are 2.0... |
TheCabinetmaker |
Dec 24 2012, 10:26 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You understand correctly, quad
SLITS |
Dec 24 2012, 11:31 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Gentlemen ....
1.7/1.8 are dual pipe that turn upward at the end. 2.0s are dual pipe the do not turn up at the end. '75 - '76 is a single pipe. |
jdlmodelt |
Dec 24 2012, 11:39 AM
Gentlemen .... 1.7/1.8 are dual pipe that turn upward at the end. 2.0s are dual pipe the do not turn up at the end. '75 - '76 is a single pipe. Okay, here's a couple of pics of the header section without the muffler. Did I mount it correctly? I first mounted it the other way around and it seemed to me that the muffler would have been hanging lower than the engine/tranny and that didn't see right. |
jdlmodelt |
Dec 24 2012, 11:42 AM
Here's another pic. Attached thumbnail(s) |
SLITS |
Dec 24 2012, 11:49 AM
From Pelican Parts Website:
Looks like you are A-OK ............. the muffler outlet will be on the drivers' side when viewing the vehicle from the front. |
jdlmodelt |
Dec 24 2012, 12:38 PM
jdlmodelt |
Dec 24 2012, 03:12 PM
From Pelican Parts Website: Looks like you are A-OK ............. the muffler outlet will be on the drivers' side when viewing the vehicle from the front. Thanks Slits...the muffler won't fit. It hits the heat shield and bumper. Is the shift linkage all that exists on the side shifter? The pic kind of shows the shift linkage? j Some models appear to show a second linkage? |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:28 AM |
