Nine_14 |
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany ![]() |
Have you ever seen this ?
Attached image(s) ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
what's the blue thing?
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,388 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Kind of resembles a stock air cleaner for a Six....a little. Oil tank up front....why would someone do that? Unless they think that by moving the oil tank up front it will also cool the oil as it travels back and forth. That has merrit but it looks wierd.
Nine_14 |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,912 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Make sure the supply line is at least 22- 24mm, Its along way to the back off the car. Its a 911 tank.
looks nontyp, but will work. |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,588 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
It's a 911 oil tank mounted up there, because it's WAY cheaper to get a used 911 tank than a stock-mount 914/6 tank.
The ones I've seen in the past are usually hacked into the rear trunk (1/2 above and 1/2 below the trunk bottom). Works just fine, but it doesn't look as polished and nice as a stock tank. edit: yes the blue thing is a painted stock 911 airbox for weber carbs. |
Nine_14 |
It's a 911 oil tank mounted up there, because it's WAY cheaper to get a used 911 tank than a stock-mount 914/6 tank. The ones I've seen in the past are usually hacked into the rear trunk (1/2 above and 1/2 below the trunk bottom). Works just fine, but it doesn't look as polished and nice as a stock tank. (IMG:style_emoticons/default/agree.gif) |
flash914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California ![]() |
Not an hijack, But could one of you point me to the plans- thread for the build it yourself alumin tank. Thanks Gordon
DEC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany ![]() ![]() |
It's a 911 oil tank mounted up there, because it's WAY cheaper to get a used 911 tank than a stock-mount 914/6 tank. The ones I've seen in the past are usually hacked into the rear trunk (1/2 above and 1/2 below the trunk bottom). Works just fine, but it doesn't look as polished and nice as a stock tank. edit: yes the blue thing is a painted stock 911 airbox for weber carbs. (IMG:style_emoticons/default/agree.gif) but my opinion is that's the badest option because the oil tank is much to low and under the engine level |
DEC |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
That's um...." special " ......... (IMG:style_emoticons/default/unsure.gif)
the extra part, as noted, is an air cleaner assy for Solex/Webers. The blue just adds to the "special-ness " here (IMG:style_emoticons/default/barf.gif) This is the front side Attached image(s) ![]() |
sixnotfour |
QUOTE That's um...." special " ......... unsure.gif don't be a hater |
Lo-Fi Version | Time is now: 19th July 2025 - 02:51 AM |
