> Which taco plate seal do I need?
last337
post Jan 10 2013, 11:39 AM
I am going to try to fix a leak on the oil temp sender but I havent taken it apart yet. I am ordering a new sending unit as well. I am confused b/c Pelican has two different ones; one being listed as for 1.7 and 1.8 and the other Im assuming for 2.0.
The problem is that this is what my sending unit looks like from bottom:
Which looks like it will take this gasket which Pelican lists as the 1.7, 1.8 gasket
This is the other one they have listed. Do I need both to fix that?
last337
post Jan 10 2013, 12:33 PM
Nevermind, I figured out that I need both. The o-ring goes on sending unit and gasket on taco plate. Duh (IMG:style_emoticons/default/wacko.gif)
luskesq
post Jan 10 2013, 01:05 PM
QUOTE(last337 @ Jan 10 2013, 10:33 AM) *
Well, you are partially correct. What you need are 2 – 6mm copper crush washers prt# N012803-2, sender crush washer prt# 900-123-007-30, gasket that goes between the two plates 039-101-287 and o-ring prt #021 101 269 A that goes between the taco plate and engine case (not the sending unit. Your pic doesn't show the cover plate that goes on top of the taco plate, then gasket, then plate.
Remember not to overtighten.
Keith
last337
post Jan 10 2013, 02:04 PM
QUOTE(luskesq @ Jan 10 2013, 01:05 PM) *
Keith
I got everything but the sender crush washer you stated. In the catalog it is listed for a 911. My sender is bad so I ordered a new one prt#323-055-M82. Is that incorrect? That is what the guys at Pelican said I needed.
Dave_Darling
post Jan 10 2013, 04:04 PM
914 Idiot
What sender you need depends on what gauge you have. For instance, aftermarket gauges have their own senders that are calibrated for the range of the gauge.
IIRC, the stock sender has been NLA for quite a few years. Using the wrong sender will give you a reading, and it will go up as the temp goes up and down as the temp goes down. It won't necessarily be in the correct part of the scale, but then again the stock gauge isn't numbered...
--DD
7TPorsh
post Jan 10 2013, 04:11 PM
7T Porsh
That sender is in there backwards, right?
luskesq
post Jan 10 2013, 04:18 PM
Dave is correct in that the needle with a mismatched gauge/sending unit will differ from a matched set; however you should get a reading. As to your question however, yes, part #900-123-007-30 should work with your new sender (if the one pictured on the Pelican site).
Keith
luskesq
post Jan 10 2013, 04:21 PM
QUOTE(7TPorsh @ Jan 10 2013, 02:11 PM) *
No.
Keith
Valy
post Jan 10 2013, 04:26 PM
I think you got the wrong sensor. The one you need has a long nose but it may be that the one you got will fit as well.
For sealing you'll need the big red oring between the sensor plate and engine case, a paper gasket between the sensor plate and the cover plate, 2 small copper washers between the holding screws and the cover plate and one bigger copper washer between the sensor and the sensor plate.
I found all the copper washers at HarborFreight
http://www.harborfreight.com/80-piece-copp...ment-67526.html
For the paper gasket you can use the link in my signature and print yours.
The oring can be sourced at many parts store. I had one on my shelf so didn't funt for it.
Always use gasket sealant on the paper gasket!
- Lo-Fi Version Time is now: 9th July 2025 - 11:53 AM
