| last337 |
Jan 11 2013, 07:15 PM
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
| Dave_Darling |
Jan 11 2013, 07:45 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,369 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Distributor: I don't see any vacuum dashpot hanging off the side of the distributor body, so it isn't a stock distributor. Probably a "009" centrifugal-only one.
The small sliver can hanging off the side of the distributor is indeed the condensor. Wire: That's the oil pressure "idiot light" sender. Turns on the oil pressure light when the pressure is very very very low. --DD |
| last337 |
Jan 11 2013, 07:50 PM
Distributor: I don't see any vacuum dashpot hanging off the side of the distributor body, so it isn't a stock distributor. Probably a "009" centrifugal-only one. The small sliver can hanging off the side of the distributor is indeed the condensor. Wire: That's the oil pressure "idiot light" sender. Turns on the oil pressure light when the pressure is very very very low. --DD Thanks! Can the idiot light sender be replaced with a oil pressure gauge in same location? |
Lo-Fi Version | Time is now: 30th November 2026 - 11:30 AM |
