last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Ugh I was all set to set timing and valve clearance today. I pushed car out of shop to clean up before starting. It came time to mo be back into shop and upon turning key I heard a pop and then nothing. Checked all under dash fuses and everything looks good. Pulled connections to relay box in engine compartment and everything looks good. If I turn on hazards I hear them clicking but see no lights. If I turn key on the hazards stop clicking. Where should I start?
last337 |
Okay so I have been troubleshooting more and I find that the interior lights will also come on but as soon as I turn key they go off as well. I checked all fuses and don't see any problems. Is there a main fuse for ignition switch somewhere? I also pulled wire from coil going to fuel pump and put straight to battery and can hear fuel pump click but not turn on. Its as if the key switch is shorting out everything.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Replace the electrical portion of the ignition switch and see if that cures the problems.
They will crack from the heat generated by power thru them and cause all sorts of problems. |
last337 |
I got it after hours of troubleshooting I finally pulled ground off and put new connections and cleaned it all up. That was it! Ugh at least I learned a valuable lesson; always check your grounds properly
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 05:49 AM |
