last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
I got my verbs dialed in pretty darn good yesterday. I only had time for a short test drive, not long enough to pull plugs for inspection. One thing I did notice is a whistling noise coming from carbs when engine was under a load. No backfiring or popping so I'm not sure what this indicates.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
It may be the normal "trumpet" of carbs. Is this the first you have driven a carbed car? I have to ask, just to rule out some things.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Yeah, carbs make a lot of noise. At above 4k rpm my old webers would be howling. Fun on short drives.
last337 |
Yes, this is first carbed car I have driven in years and def first air cooled vehicle. I find it has a nice lope to it when idling at around 900rpm. When it comes up under load it whistles around 2500 then has a nice sound around 3k. I just want to make sure I'm not running too lean but I guess I won't know till I check plugs. I have all carbs just above falling off with mix screw and each pulling about 3.5-4 on STE reading. Like I said, it has a nice lope but still a smooth idle not shaky
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Dellortos? They have a slot in the base that whistles unless you use a special gasket to seal it or what many do is epoxy the grove solid.
last337 |
last337 |
Is that just the way things will sound with carbs? Is that lope normal or could it indicate a different can? I'd like to know what cam I have. Is there a way to know looking at valve train or would I have to open things up?
vw505 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None ![]() |
Ya, I was going to say some carbs just whistle, my webber 44's bark.
Lo-Fi Version | Time is now: 3rd July 2025 - 01:16 AM |
