battery tray, advise |
underdog |
Jan 19 2013, 12:03 PM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
Hey Guys, just found corrosion and rust under the battery. I think the tray is solid as this looks like surface crap. I will clean all this out using dremel but need input as how to treat the metal afterwards. Thanks.
timothy_nd28 |
Jan 19 2013, 12:14 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I replaced the evap coil on my dodge durango, which required me to rip the dash out. During that process, I had to pull up the carpet to remove some heater duct. To my amazement, the floor boards were painted with some hard plasticy material from the factory. What ever that stuff was, it would be great to use for the battery tray area, and the longs. My googling efforts are coming up short with this mysterious factory paint. Do not use Por15, it simply doesn't work.
mr914 |
Jan 19 2013, 03:04 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
(IMG:style_emoticons/default/WTF.gif)
I've used POR-15 for 20+ years. It works in most applications where the metal is properly cleaned. It's not so great on shinny new "pickled" metal, but old rusty/crusty surfaces work good |
Lo-Fi Version | Time is now: 4th June 2024 - 10:46 AM |
