battery acid, 2 questions. |
underdog |
Jan 22 2013, 09:24 AM
Member Group: Members Posts: 82 Joined: 20-September 11 From: Mountain Home, AR Member No.: 13,579 Region Association: None |
Are the pads the battery sits on worthwhile?
Is there a battery that does not emit the bad stuff? Thanks All. |
billh1963 |
Jan 22 2013, 09:34 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Pads help if you use a traditional battery. They are not perfect. Best bet is to get a closed battery like Optima. Lots of threads on the subject
sean_v8_914 |
Jan 22 2013, 09:37 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
and some 99 cent felt washers to go around the terminals. red and green, sold at most parts stores
Spoke |
Jan 22 2013, 09:49 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Best bet is to get a closed battery like Optima. (IMG:style_emoticons/default/agree.gif) Battery acid and 914s don't go well together. Best to stay away from lead acid batteries. |
r_towle |
Jan 22 2013, 10:28 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Annual removal of the battery and washing the entire area with a mix of baking soda and water in a spray bottle, with a rinse of water also does wonders.
Baking soda is a base that counteracts the acid from the batteries and , for me anyways, is a typical annual job...not fun but satisfying to see all the hard work is still clean. I do this to all my lead acid battery cars.... I also touch up any paint issues at the time. You need to remove the computer from its location and twist upside down to get into all the right places. I have added an additional drain tube at the lowest point of the longitudinal with a small pipe welded in to divert any draining around the heater tube abd out below the longitudinal. BUT Paper towels and a good thorough job also works... rich |
dfelz |
Jan 22 2013, 10:33 AM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
Underdog, I have an odyssey racing battery for sale if you are interested. Heres the link to the FS post
http://www.914world.com/bbs2/index.php?showtopic=201868 |
Jasfsmith |
Jan 22 2013, 12:11 PM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
rex66m |
Jan 22 2013, 02:44 PM
Member Group: Members Posts: 100 Joined: 3-August 11 From: Birmingham, AL Member No.: 13,393 Region Association: None |
[quote name='r_towle' date='Jan 22 2013, 12:28 PM' post='1807132']
Annual removal of the battery and washing the entire area with a mix of baking soda and water in a spray bottle, with a rinse of water also does wonders. Baking soda is a base that counteracts the acid from the batteries and , for me anyways, is a typical annual job...not fun but satisfying to see all the hard work is still clean. I do this to all my lead acid battery cars.... I also touch up any paint issues at the time. You need to remove the computer from its location and twist upside down to get into all the right places. I have added an additional drain tube at the lowest point of the longitudinal with a small pipe welded in to divert any draining around the heater tube abd out below the longitudinal. BUT Paper towels and a good thorough job also works... rich I need to do this. Is the computer an easy deinstallation? Tks |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:00 AM |
