Turn signal and brake lights will not turn on Dash, Compatible relays for signal flasher |
juliomagdaleno |
Jan 29 2013, 11:06 AM
Newbie Group: Members Posts: 24 Joined: 8-January 13 From: austin Member No.: 15,350 Region Association: None |
I have a 1974 porsche with a 2.0 I am trying to get to pass inspection. I purchased the car about 3 weeks ago and am trying to work out all the bugs. The turn signals did not work and i fixed the problem, they all work now including the hazards. The problem is the turn signal light on the dash does not blink. The bulb is good and there is no power going to the bulb. It is a blue wire with white marks that comes from the relay with no power. Is it the relay that is bad, i tried to find the relay local, Austin TX, and have been unsuccessful, guess i have to order the part. I tried using a Tridon EP26 relay but i guess this is not the correct relay. Anyone have any suggestions, is it the relay or should i be looking at something else.
I also have a problem with the parking brake light, is there a relay for this and what should i look for to make this light turn on. thanks |
LotusJoe |
Jan 29 2013, 12:35 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I have a 1974 porsche with a 2.0 I am trying to get to pass inspection. I purchased the car about 3 weeks ago and am trying to work out all the bugs. The turn signals did not work and i fixed the problem, they all work now including the hazards. The problem is the turn signal light on the dash does not blink. The bulb is good and there is no power going to the bulb. It is a blue wire with white marks that comes from the relay with no power. Is it the relay that is bad, i tried to find the relay local, Austin TX, and have been unsuccessful, guess i have to order the part. I tried using a Tridon EP26 relay but i guess this is not the correct relay. Anyone have any suggestions, is it the relay or should i be looking at something else. I also have a problem with the parking brake light, is there a relay for this and what should i look for to make this light turn on. thanks Parking brake uses the same relay as the turn signals. I would suspect that the parking brake switch is not connected to ground. Auto Atlanta stocks the proper turn signal relay. |
juliomagdaleno |
Jan 29 2013, 01:37 PM
I have a 1974 porsche with a 2.0 I am trying to get to pass inspection. I purchased the car about 3 weeks ago and am trying to work out all the bugs. The turn signals did not work and i fixed the problem, they all work now including the hazards. The problem is the turn signal light on the dash does not blink. The bulb is good and there is no power going to the bulb. It is a blue wire with white marks that comes from the relay with no power. Is it the relay that is bad, i tried to find the relay local, Austin TX, and have been unsuccessful, guess i have to order the part. I tried using a Tridon EP26 relay but i guess this is not the correct relay. Anyone have any suggestions, is it the relay or should i be looking at something else. I also have a problem with the parking brake light, is there a relay for this and what should i look for to make this light turn on. thanks Parking brake uses the same relay as the turn signals. I would suspect that the parking brake switch is not connected to ground. Auto Atlanta stocks the proper turn signal relay. I just ordered a replacement uro switch, hope this works. I was hoping there was something i could cross reference. |
LotusJoe |
Jan 29 2013, 01:52 PM
I got one from my local parts supplier (SSF) and it was the same URO, so it should work fine.
Mike Bellis |
Jan 29 2013, 08:22 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have a 1974 porsche with a 2.0 I am trying to get to pass inspection. I purchased the car about 3 weeks ago and am trying to work out all the bugs. The turn signals did not work and i fixed the problem, they all work now including the hazards. The problem is the turn signal light on the dash does not blink. The bulb is good and there is no power going to the bulb. It is a blue wire with white marks that comes from the relay with no power. Is it the relay that is bad, i tried to find the relay local, Austin TX, and have been unsuccessful, guess i have to order the part. I tried using a Tridon EP26 relay but i guess this is not the correct relay. Anyone have any suggestions, is it the relay or should i be looking at something else. I also have a problem with the parking brake light, is there a relay for this and what should i look for to make this light turn on. thanks The flasher relay is a dual relay. The dash lamp connection is a separate function from the exterior lamps. I suspect you need a new flasher relay. The new switch may not fix the problem. The switch has no effect on the dash lamp. Even if you hear it "click", the relay can still be bad. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:05 AM |
