Steering Hub Question, Momo hub - Dino wheel |
MarkV |
May 16 2003, 09:49 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I have a momo mount & just bout a Dino wheel. The Dino wheel has a slightly larger bolt patern that the Momo hub. Do they still make a Dino hub for a 73 914?
Also looks like the Dino wheel may work better w/ 5mm mach. screws vs. the 4mm the Momo takes. Has anybody re-drilled a Momo hub to fit a Dino wheel? When I mount the hub in the car there is a 1" gap between the Momo hug & the horn mechanism. I assume this gap is for the horn wiper contact. Am I missing a cover or do I have the wrong hub. The hub bolts on w/ no problem. I bouht the hub & wheel from different sellers on e-bay. (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
MarkV |
May 16 2003, 09:50 PM
close-up
Attached image(s) |
Qarl |
May 16 2003, 09:51 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Is that a silver-spoked Momo Prototipo wheel on the right?
There's some guy looking for one on the PP 911 forum. Regards, Karl |
MarkV |
gap-osis
Attached image(s) |
Curvie Roadlover |
May 16 2003, 09:52 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Damn, so close, yet so far away. Maybe if you mounted the wheel with screws and drove them in on an angle........ (IMG:style_emoticons/default/blink.gif)
MarkV |
May 16 2003, 09:54 PM
Karl, Yes it is a silver spoke Prototipo on the right. It is the small diam. model 320 0r 330mm. The leather is not in good condition. I have been looking for a 350mm Prototipo when I found the Dino dirt cheap.
Qarl |
Umm... that gap for the steering column doesn't look right.
Is that hub adapter in all the way? And that hub doesn't look like the Momo hub I have. It seems longer. Do you want me to take a picture of my setup? Regards, Karl |
Curvie Roadlover |
May 16 2003, 09:55 PM
I have a MOMO hub and wheel, and I can tell you my hub is not as long as the one in your pic. Also no gap to the steering column. Are you sure that's the right hub? (IMG:style_emoticons/default/confused24.gif)
Aaron Cox |
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i dont think the gap is supposed to be there at all <_<
Aaron Cox |
May 16 2003, 09:56 PM
here is a solution:
send me a $20.... ill send you a personal wheel adapter and you can redrilll it (IMG:style_emoticons/default/biggrin.gif) sound like a plan? (IMG:style_emoticons/default/laugh.gif) |
Curvie Roadlover |
May 16 2003, 09:57 PM
Also, on mine the diameter of the hub matches the diameter of the steering column. I notice in your pic the hub is quite a bit bigger than the steering column.
MarkV |
May 16 2003, 10:03 PM
There are three holes on the back of the adapter to attach the horn wiper. So, I think the gap has to be there. I must be missing some kind of cone shaped cover.
The spilne is right and the wheel draws down to the shoulder on the shaft. |
Qarl |
May 16 2003, 10:06 PM
Even with some "cone adapter" it still doesn't look right. It also looks like it sets the wheel too far away from the column. I think it's because the adapter is longer than normal and because of the gap.
The Momo hub I have, has the horn adapter recessed into the back of the hub, so there isn't a gap. Just trying to help. Regards, karl |
Curvie Roadlover |
May 16 2003, 10:07 PM
QUOTE(kellzey @ May 16 2003, 08:06 PM) The Momo hub I have, has the horn adapter recessed into the back of the hub, so there isn't a gap. Yup, mine too. |
Qarl |
May 16 2003, 10:19 PM
Here's my Momo hub and Prototip wheel.
Attached image(s) |
Qarl |
May 16 2003, 10:21 PM
Oooooohhh... shiny wheel.... (drool)
I love this steering wheel. I can't wait to drive with it in the final finished conversion project with it. I think I will install it last as the crowning touch. Regards, Karl Attached image(s) |
MarkV |
May 16 2003, 10:22 PM
I don't have anything for reference other than the stock wheel. I was always running into the dash, turn signals & wipers w/ my hands. I now have 4" of clearance from the dash & 2 1/2" from the wiper & signal stalks. It feels better but I obviously can't drive it w/ 2-4mm screws holding the wheel on.
Anyone have pictures of their set-up? (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) Attached image(s) |
Qarl |
May 16 2003, 10:24 PM
Look two replies above. We were probably typing at the same time!
Karl |
MarkV |
May 16 2003, 10:29 PM
Thanks Karl,
Nice wheel!! The hub I have looks longer & bigger in diameter. My hub is 3 1/2" long, 4 1/2" if the "cone" was there. |
MarkV |
May 16 2003, 10:49 PM
Mine has a rubber boot w/ like a built-in crumple zone. (IMG:style_emoticons/default/confused24.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:14 PM |
