MarkV
May 16 2003, 09:49 PM
I have a momo mount & just bout a Dino wheel. The Dino wheel has a slightly larger bolt patern that the Momo hub. Do they still make a Dino hub for a 73 914?
Also looks like the Dino wheel may work better w/ 5mm mach. screws vs. the 4mm the Momo takes. Has anybody re-drilled a Momo hub to fit a Dino wheel?
When I mount the hub in the car there is a 1" gap between the Momo hug & the horn mechanism. I assume this gap is for the horn wiper contact. Am I missing a cover or do I have the wrong hub. The hub bolts on w/ no problem.
I bouht the hub & wheel from different sellers on e-bay.
MarkV
May 16 2003, 09:50 PM
close-up
Qarl
May 16 2003, 09:51 PM
Is that a silver-spoked Momo Prototipo wheel on the right?
There's some guy looking for one on the PP 911 forum.
Regards,
Karl
MarkV
gap-osis
Curvie Roadlover
May 16 2003, 09:52 PM
Damn, so close, yet so far away. Maybe if you mounted the wheel with screws and drove them in on an angle........
MarkV
May 16 2003, 09:54 PM
Karl, Yes it is a silver spoke Prototipo on the right. It is the small diam. model 320 0r 330mm. The leather is not in good condition. I have been looking for a 350mm Prototipo when I found the Dino dirt cheap.
Qarl
Umm... that gap for the steering column doesn't look right.
Is that hub adapter in all the way? And that hub doesn't look like the Momo hub I have. It seems longer.
Do you want me to take a picture of my setup?
Regards,
Karl
Curvie Roadlover
May 16 2003, 09:55 PM
I have a MOMO hub and wheel, and I can tell you my hub is not as long as the one in your pic. Also no gap to the steering column. Are you sure that's the right hub?
Aaron Cox
i dont think the gap is supposed to be there at all <_<
Aaron Cox
May 16 2003, 09:56 PM
here is a solution:
send me a $20....
ill send you a personal wheel adapter
and you can redrilll it
sound like a plan?
Curvie Roadlover
May 16 2003, 09:57 PM
Also, on mine the diameter of the hub matches the diameter of the steering column. I notice in your pic the hub is quite a bit bigger than the steering column.
MarkV
May 16 2003, 10:03 PM
There are three holes on the back of the adapter to attach the horn wiper. So, I think the gap has to be there. I must be missing some kind of cone shaped cover.
The spilne is right and the wheel draws down to the shoulder on the shaft.
Qarl
May 16 2003, 10:06 PM
Even with some "cone adapter" it still doesn't look right. It also looks like it sets the wheel too far away from the column. I think it's because the adapter is longer than normal and because of the gap.
The Momo hub I have, has the horn adapter recessed into the back of the hub, so there isn't a gap.
Just trying to help.
Regards,
karl
Curvie Roadlover
May 16 2003, 10:07 PM
QUOTE(kellzey @ May 16 2003, 08:06 PM)
Yup, mine too.
Qarl
May 16 2003, 10:19 PM
Here's my Momo hub and Prototip wheel.
Qarl
May 16 2003, 10:21 PM
Oooooohhh... shiny wheel.... (drool)
I love this steering wheel. I can't wait to drive with it in the final finished conversion project with it. I think I will install it last as the crowning touch.
Regards,
Karl
MarkV
May 16 2003, 10:22 PM
I don't have anything for reference other than the stock wheel. I was always running into the dash, turn signals & wipers w/ my hands. I now have 4" of clearance from the dash & 2 1/2" from the wiper & signal stalks. It feels better but I obviously can't drive it w/ 2-4mm screws holding the wheel on.
Anyone have pictures of their set-up?
Qarl
May 16 2003, 10:24 PM
Look two replies above. We were probably typing at the same time!
Karl
MarkV
May 16 2003, 10:29 PM
Thanks Karl,
Nice wheel!!
The hub I have looks longer & bigger in diameter. My hub is 3 1/2" long, 4 1/2" if the "cone" was there.
MarkV
May 16 2003, 10:49 PM
Mine has a rubber boot w/ like a built-in crumple zone.
Qarl
May 16 2003, 10:53 PM
Please refrain from posting pictures of your backside on this group.
We've already seen enough of other poster's backsides!
Regards,
Karl
Curvie Roadlover
May 17 2003, 07:32 AM
My hub is the same as Kellzey's. It is too close to the dash though and I was banging the wiper/turn signal arms during "spirited" driving. I bought a steering wheel spacer from a place in FLA called FVD-USA for 20 bucks that moved the wheel out about .75" not much but enough to fix the banging into the wiper/blinker arms. It is also offset a bit so my wheel is now a bit higher when the wheels are pointing straight
- -and a bit lower when I turn the wheel 180 degrees
MarkV
May 17 2003, 09:50 AM
QUOTE(acox914 @ May 16 2003, 07:56 PM)
here is a solution:
send me a $20....
sound like a plan?
Aaron,
What is the bolt patern of your hub? I need 6 on 74mm center w/ 5mm screws.
Thanks
Jeroen
May 17 2003, 10:04 AM
Go to the
TC Racing website
The hubs they sell are the same bolt patern as the Dino
Good news, the hubs are cheap too ($30 IIRC)
cheers,
Jeroen
Andyrew
May 17 2003, 10:41 AM
Mine has a ruber boot, I had a problem like that, let me take a pic....
Andyrew
May 17 2003, 10:48 AM
pic
Andyrew
May 17 2003, 10:49 AM
pic
Andyrew
May 17 2003, 10:51 AM
$80 wheel with hub at swap meet! I love good deals.
Ps, ignore the foot, I just got up.
Jeroen
May 17 2003, 11:03 AM
BTW, the hub you have is prolly for a later style 911 (up to '89)
Oh, and that Personal hub that Aaron has will fit your Dino wheel as well
cheers,
Jeroen
Andyrew
May 17 2003, 11:09 AM
Jeroen, If your talking to me, Yes the hub is for a 911, but it fit my car (yay) asside from the, oh how do you say it, offset? So I just put the hub from the stock wheel in as a spacer, it wiggles around, but the wheel and hub attached to the wheel is firmly mounted, so no worries for me.
Jeroen
May 17 2003, 11:49 AM
Hey Andrew,
I was actually talking about the pics of Mark V's hub
cheers,
Jeroen
abm914
May 17 2003, 04:13 PM
Guys
Hi there, I'm having the same problem finding a steering hub for my '71 914. I've tried the 'early' momo hub (same as Mark's) but it leaves a large gap. A fellow '14ner let me try his later Momo hub (like Karl's) but it wouldn't go on the steering shaft (and a didn't want to force it on too hard as the guy who lent it was sitting next to me!). His '14 is a '73 so it should fit on Mark's car without a gap.
Does any one have a pre72 car with a momo wheel on it?
Also, PP sell an adaptor/extender, does anyone have one of these?
PP Wheel adaptorAdam
Aaron Cox
May 17 2003, 04:20 PM
QUOTE(MarkV @ May 17 2003, 07:50 AM)
here is a solution:
send me a $20....
and you can redrilll it :D
sound like a plan?
Aaron,
Thanks
i was just screwin around....you can seriously have it if you want it. i have absolutely no use for it! interested....i tried giving it away on a game like thread but no go
jim_hoyland
May 17 2003, 09:20 PM
I had the same thing with the Momo. I took the bottom off the original Porsche Steering wheel. I t has the turn signal return on it; then I carefully, repeat carefully, drilled holes on the bak of the adapter, and tapped them for the screws.
Turned out to be a perfect solution and my turn signal return works too.
MarkV
May 29 2003, 08:44 PM
My wheel hub arrived from TC Racing today. This one has the right bolt pattern, but it has the same 1" gap behind the hub like the momo adapter that I have. As you can see from the photo, the gap is too small to mount the back from the factory wheel in the space allowed.
I tried to get information from TC Racing before I ordered. They have a machine that answers the phone & they don't return e-mail.
Does anyone have a solution?
MarkV
May 29 2003, 08:45 PM
abcd
Aaron Cox
May 29 2003, 08:48 PM
well, you can still have mine....like i told you in the email...it must have been dropped , has a small "dent". PM, if you want it.....
of course, a lot less than 20 bucks!
MarkV
May 29 2003, 08:56 PM
Does it look like this?
Aaron Cox
May 29 2003, 09:02 PM
NOPE! it is EXACTLY (yes EXACTLY, i busted out the dial calipers)
height: 3.72 "
Diameter: 3.53 "
Wall thickness: .08"
has 6 bolts for the wheel itself. the rear side of it is quite recessed. my dad should bring the didgital camera home tommorow. ill snap a few then ok?
seanery
May 29 2003, 09:03 PM
I've got that same hub on my car and it works great! No gap.
seanery
May 29 2003, 09:08 PM
PP Wheel adaptor
I think Brad is running these on Lyressa's car.
seanery
May 29 2003, 09:21 PM
It's on my 74. It's 2000 miles away or I'd take a pic for you.
MarkV
May 29 2003, 09:39 PM
As you can see the factory wheel spline is deep in a recess. The aftermarket hub has the spline on the end.
Are you guys getting tired of my problem? You know I have more photos.
Aaron Cox
May 29 2003, 09:42 PM
if that is the case, then i think mine will solve your prob! mine goes about an inch past yours (toward the steerring collumn)
Malmz
May 29 2003, 11:16 PM
Ha! I have two of the same problems as Mark. I bought the same adaptor from TC Racing and it fits the same (gap), and they never returned any of my e-mails after the purchase and the note on their invoice that said "let us know if you need anything...".
FWIW, mine is a 74 and should have the stock column on it.
I also bought the quick release from them which is a very nice piece and works great, but still have the gap and no customer service...
I haven't gone back into the car recently to try to work something out, it's still on my "to do" list...
sm
Jeroen
May 30 2003, 05:51 AM
Hmmm... this is weird.
Carolina from TC Racing was very helpfull when I ordered my quickrelease.
We swapped several e-mails before I ordered and she always responded within a day
I didn't order the hub though (already had a Raid hub).
I'll measure the backside of my Raid hub when I get home 2nite...
cheers,
Jeroen
May 30 2003, 10:55 AM
anyone wants to trade a early momo hub for a late momo hub ???
i have a early one, upgraded my car to a late style steering column and now the old hub doesn't fit anymore.
it's about an inch too long!
Mark, could that be the solution to your problem? maybe you have a "early" column!
Andy
seanery
May 30 2003, 10:58 AM
that sounds/looks like the problem.
MarkV
May 30 2003, 11:09 AM
Read Malmz response above. I think I just bought a paper weight. :finger2:
My car is a 73 and I am almost positive it has the factory column. Early columns are 70-71 only.
Andy, do you have a photo of your column minus the wheel?
May 30 2003, 11:20 AM
QUOTE(MarkV @ May 30 2003, 10:09 AM)
they're all too blurry ... haha
maybe brad could shoot some pics of the column and the old hub today.
he sais it's a '75 column.
Hey Mueller, didn't i get that column from you? what year is it?
the early adapter fits, but it's about 1" too long, can't get the nut back on,
the tip of the column barely sticks out through the hub ...
Andy
