MarkV
May 30 2003, 11:33 AM
Andy, I have a Momo hub that bolts up to late column. It has a gap like the Dino hub. You can have it if you need a hub until you can find something else.
May 30 2003, 11:37 AM
QUOTE(MarkV @ May 30 2003, 10:33 AM)
yes!
that would be very cool. i really like to keep my old momo, i like them much better than the new ones ...
Andy
Jeroen
May 30 2003, 12:09 PM
Here's some pics of my Raid (Dino) hub
cheers,
Jeroen
Jeroen
May 30 2003, 12:10 PM
asdf
Jeroen
asdf
Jeroen
Car is a '72 BTW
cheers,
Jeroen
May 30 2003, 12:17 PM
hey, Jeroen, where's your Car in that pic? all i can see is the Garage-Floor!
Jeroen
May 30 2003, 12:18 PM
The missing pieces are piled up in a corner of the garage
cheers,
Jeroen
MarkV
May 30 2003, 12:33 PM
Well there is the problem. The hub from TC Racing has the spline in a completely different place.
May 30 2003, 12:44 PM
QUOTE(MarkV @ May 30 2003, 11:33 AM)
hmmm, even if you remove the horn ring from the original?
it seems like without that, the position should be pretty close ...
Andy
Jeroen
May 30 2003, 01:06 PM
Ok, maybe this is a stoopid suggestion, but did you try to mount the splined bottom of the hub upside down
(remove the 4 screws, turn the bottom part around, so the splined part goes into the hub)
cheers,
Jeroen
MarkV
May 30 2003, 01:37 PM
Those aren't scews they are casting holes. It can't be disassembled.
Aaron Cox
May 30 2003, 06:37 PM
okay, here be some pics....
here is the top (front- the side facing the wheel)
Jeroen
May 30 2003, 06:39 PM
QUOTE(MarkV @ May 30 2003, 09:37 PM)
I would swear I'm seeing 4 allen screws in your pic...
cheers,
Jeroen
seanery
May 30 2003, 06:41 PM
Jeroen,
I see them too.
Aaron Cox
here is the side....w/ a gauge caliper for reference
Aaron Cox
May 30 2003, 06:46 PM
here is the bottom view...the red arrows poit to the "indent" and the blue point to some sort of button thing
green arrow points to PN
Aaron Cox
May 30 2003, 06:48 PM
markv, this is what you will be recieving
MarkV
May 30 2003, 06:49 PM
Jeroen,
You are correct. I was at work when I saw your post.
Had a hard tome getting it apart, assembled w/ some kind of thread lock. If I flip it over the shaft doesn't come through the center far enough to get the washer & nut on. Doesn't change the "gap" very much either.
I looked at the photo of your column & mine looks the same.
Thanks
May 31 2003, 09:16 AM
QUOTE(acox914 @ May 30 2003, 05:46 PM)
and the blue point to some sort of button thing :)
your hub looks like an early one.
that "button thing" is the contact for the horn, which is a springloaded graphite pin that rubs on the metal ring that goes on the streering column.
that is a early (pre '72) setup ...
later models have the horn-ring on the hub and a flat metal contact on the steering column.
Andy
MarkV
Jun 10 2003, 12:17 AM
Arron sent me a hub that I got to work.
It fit over the existing column but made contact w/ the turn signal & wiper switches so I had to cut it down 3/8".
It was drilled for 5mm screws so I had to tap it to 6mm.
Had to extend the horn ring 1/2" to make it work. The scews for the horn ring are 3.5mm and are hard to find.
I used the boot from the other hub, doesn't look so big that way.
MarkV
Jun 10 2003, 12:27 AM
Jereon & Malmz, I did get a response back from TC Racing. The hubs they sell are "for racing purposes only" w/ no provisions for horn or signal cancel.
Malmz
Jun 10 2003, 07:06 AM
Horn or cancellation wasn't really my issue, just the big-ass gap is. It seems like they don't know that their hubs don't fit all years of 914s (that there are different offsets) unless I'm missing something.
I need to take a pict of mine, but it looks like one of the other ones posted.
Congratulations on actually getting a response though! Wish they gave me that courtesy.....
sm
MarkV
Jun 10 2003, 10:50 AM
This is what TC Racing had to say about the big ass
gap:
Hi Mark, I spoke to our shop foreman regarding the problem you found. Marco is the one that had replied to your original inquiry letting you know that this hub would not allow a setup with no gap. He does not know of a way to fill the gap.
Also, it is dificult to install a horn with some of our hubs and this one is one of them.
Please keep in mind this IS a racing setup, not intended for street use.
Carolina
Note: forwarded message attached.
Carolina Capote
4467 Chickasaw Rd
Memphis TN 38117 USA
Tel: 901-921-9921
Fax: 901-821-0116
Lawrence
Jun 10 2003, 11:32 AM
I just went to the Momo website (www.momo.it).
Talk about a site that's an overdesigned, bandwidth-hogging, difficult to navigate POS.
Someone sure made their money designing THAT site. :finger2:
-Rusty
P.S. I have a big-ass gap on my hub adapter, too. But at least I have a horn and signals.
MarkV
Jun 10 2003, 11:51 AM
Rusty, I think Andy may have a hub that will fix your problem. He converted from an early column to a late column & has an early Momo adapter than won't work on his car. I sent him a late Momo adapter that has a big ass
gap.
Aaron Cox
Jun 10 2003, 05:33 PM
like i said.....glad to see ya got it to work. always good to see someone getting use out of something i cant
ps, anyone seen the GRANT steering wheels on ebay? kinda cool but pricey tho!
