> Tin question for AC car
stateofidleness
post Feb 10 2013, 07:47 PM
Gents,
In the middle of a teardown and cleaning up the tin and stuff... I have a '73 1.7 with A/C and one of the tin pieces fits kind of goofy. I want to straighten it out before painting, but I'm not sure how it's supposed to fit... I've attached a few pics showing different angles of it before removal. I'm wondering if that indented part where the screw is on top is supposed to be dented in like that or perfectly domed? It doesn't seem like that rise is tall enough to allow the flat part of the tin to sit flat. In the 3rd pic, you can see where I hammered it out and it seems a little better, but I was hoping someone was familiar with this tin piece and could confirm what it's supposed to look like. Any reference pics of it?
dlee6204
post Feb 10 2013, 07:50 PM
Howdy
QUOTE(Spoke @ Feb 10 2013, 06:54 PM) *
I've never seen this part. It goes on the brake reservoir? Got a pic with it on?
It's not suppose to be dented. I'll post a picture if I have one.
Slight Hijack: How was your compressor driven off the front of the motor? (IMG:style_emoticons/default/rolleyes.gif)
stateofidleness
post Feb 10 2013, 07:53 PM
There's a pulley on the front of the impeller fan. Compressor mounted on a steel bracket just above the fan housing with a centered pulley on the compressor.
CMONNETT
post Feb 10 2013, 07:56 PM
It should be flat. It looks quite different from other 914's I've had with AC. The way the tin is cut is what I'm referring to.
dlee6204
post Feb 10 2013, 07:57 PM
Howdy
Cool. Thanks!
stateofidleness
post Feb 10 2013, 08:05 PM
Awesome pic! Didn't even cross my mind that mine was cut out on that one side like that. That's where my big steel bracket thing is bolted to and goes up and lays flat on top (a big "L" shaped piece that goes up the side and lays flat on top of the housing.
You can see in my second pic the "seam" on that piece appears to have been cut or broken at some point. Should I weld that seam closed?
dlee6204
post Feb 10 2013, 08:11 PM
Howdy
Yup, weld away.
stateofidleness
post Feb 10 2013, 08:15 PM
You guys are awesome! (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 11th November 2026 - 04:15 AM
