Seat belt reel mount location, Need picture |
Mblizzard |
Feb 12 2013, 09:15 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Does anyone have a good photo of where the seat belt reel should mount in a 1975? Mine are on the floor behind seat and they stop seat from moving back. I remember them being mounted higher up on the pillar?
Sorry about pic quality. Attached image(s) |
euro911 |
Feb 13 2013, 12:07 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
They mount on the far ends of firewall, just below the rear window. You'll need to remove the back pad to install them. Once the back pad is off, you'll see the 'wells' the 'reels' mount in.
The threaded holes in the B pillars are for the 'hoops' the belts runs through so the belts run across your shoulders The threaded holes in the longs near the back of the seats are where the other end of the belts secure. Looked for some pix, this is all I could find quickly Attached image(s) |
Mblizzard |
Feb 13 2013, 09:52 PM
They mount on the far ends of firewall, just below the rear window. You'll need to remove the back pad to install them. Once the back pad is off, you'll see the 'wells' the 'reels' mount in. The threaded holes in the B pillars are for the 'hoops' the belts runs through so the belts run across your shoulders The threaded holes in the longs near the back of the seats are where the other end of the belts secure. Looked for some pix, this is all I could find quickly Wow! Thanks so much. I knew that was the case but I just could not confirm it. I think someone just took a number of short cuts on this car. If you could not tell from the picture, this was a very unsafe condition. Thanks for the response. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:06 AM |
