adiokyro |
Oakland, Ca ![]() ![]() Group: Members Posts: 74 Joined: 27-January 13 From: United States Member No.: 15,437 Region Association: Northern California ![]() |
hi--searched around a bit, and checked my wilson book, I am tearing down my 2 liter on the stand (first ever engine tear down), Im to the point where I need to pull the oil pump, I removed the four nuts, but it will not budge, not even a little!! I have: used wilson's idea of prying two screwdrivers at once, used the back of a hammer, banged it to death with a rubber mallet, cursed at it loudly, more cursing. and nothing. I mean not even a slight inkling of movement at the mounting surfaces-----any ideas?
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
hi--searched around a bit, and checked my wilson book, I am tearing down my 2 liter on the stand (first ever engine tear down), Im to the point where I need to pull the oil pump, I removed the four nuts, but it will not budge, not even a little!! I have: used wilson's idea of prying two screwdrivers at once, used the back of a hammer, banged it to death with a rubber mallet, cursed at it loudly, more cursing. and nothing. I mean not even a slight inkling of movement at the mounting surfaces-----any ideas? You probably missed a case nut. There is one near the oil pump. |
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
yup loosen the case nuts around the pump....
adiokyro |
Thanks! I <3 914world.
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Loosen the case nuts and be careful with the screwdrivers on the tabs as you might brake something eventually.
Lo-Fi Version | Time is now: 12th July 2025 - 04:52 PM |
