911 hubs on 914 Struts? |
Kevins911 |
Feb 18 2013, 04:05 PM
Member Group: Members Posts: 52 Joined: 15-July 05 From: Kelowna, B.C. Member No.: 4,420 Region Association: Canada |
Trying to go 5 lug on a budget, I had these 911 front hubs on the shelf and was curious if they would work. They seem to fit fine, the bearings all sit where they need to, the only issue I can see is the inner bearing seal not fitting the spindle, no problem really, just get a custom seal from the local auto parts store.
The car is a '73. Does anyone see a problem with this? Thanks Kevin |
Spoke |
Feb 18 2013, 04:29 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
May be an issue with the rotor and existing 914 caliper. Not sure if there are early 911 solid rotors as the 914 caliper is for solid rotor.
Kevins911 |
Feb 18 2013, 04:35 PM
Some early 911's/912's used solid rotors, but I plan on using vented rotors with either M calipers or these 4 piston calipers. I expect to have to machine some material of the caliper mounting ears either way as I think the mounting offset changed in '73.
914Sixer |
Feb 18 2013, 08:02 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You have to have a 911 strut to use the 911 hub. A former unnamed member here used to make a conversion hub to use the 911 rotor and vented disc on the 914 strut. I have not seen on in about 10 yrs now.
Eric_Shea |
Feb 18 2013, 08:11 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
That appears to be either a very early 911 hub (which should not fit on a 914 spindle) or a 65 356C hub. The hub does not look familiar at all. Again, 911 spindles are larger than 914 spindles so I'm not sure how that is fitting on that spindle unless there's some different bearings over stock in there.
Kevins911 |
Feb 18 2013, 08:56 PM
Kevins911 |
Feb 18 2013, 08:58 PM
Lo-Fi Version | Time is now: 9th June 2024 - 05:03 PM |
