copper oil drain plug washer, did I buy the right one ? |
913B |
Mar 6 2013, 08:40 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So I bought this rolled copper washer but I think it is too big, is it supposed to compress and close the distance to the plug.
The drain plug diameter is 12mm, the washer is 14mm ID and 20mm OD, something tells me I bought the wrong one. Should I have purchased 12mm ID ones instead ?? Let me know what you think. Sorry my 1.7 engine did not have the correct washer to begin with. So I dont have an original one to compare. If anyone has source for them it would be appreciated. Thank you Ted |
michael7810 |
Mar 6 2013, 08:42 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I have about 6 just like yours. I ended up using a plastic drain plug seal from NAPA. I think the bigger ones fit type I engines. Hope someone can ID a source for the correct ones.
mrbubblehead |
Mar 6 2013, 08:54 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
tod914 |
Mar 6 2013, 09:09 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Pretty sure you can use the crush washer from the sump screen gasket kit.
larss |
Mar 7 2013, 08:26 AM
Member Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Pretty sure you can use the crush washer from the sump screen gasket kit. (IMG:style_emoticons/default/agree.gif) |
reharvey |
Mar 7 2013, 08:47 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Thanks for this link. I just bought a dozen of these. Ray |
Cap'n Krusty |
Mar 7 2013, 09:00 AM
Thanks for this link. I just bought a dozen of these. Ray Nice link, too bad it's for the WRONG gaskets, and too bad you wasted your money on them. Maybe the provider of the link will take 'em off your hands, postage and all. Or not. BTW, when you do get the correct washers, note that the split side of the washer goes toward the head of the bolt, NOT toward the threaded part. The Cap'n |
Lo-Fi Version | Time is now: 28th May 2024 - 06:25 PM |
