OT: Ford Taurus question, GEM Module ?? |
WoMBaT |
Nov 20 2004, 02:42 PM
Member Group: Members Posts: 69 Joined: 29-June 04 From: Fort Riley, Kansas Member No.: 2,272 |
Does anybody who owns a late model taurus know which is the GEM Module? I am installing an automatic starter...and need to know what I'm looking for. Is it the same assembly that the fuse box is connected to? Anyone got pictures??
WoMBaT |
Brett W |
Nov 20 2004, 08:41 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
It will probably need a transmission when you are done.
WoMBaT |
Nov 21 2004, 01:43 PM
QUOTE It will probably need a transmission when you are done. Why so? Seems to be fine, low miles and all. |
WoMBaT |
Nov 21 2004, 01:46 PM
Has anyone successfully installed one of these remote starters in a vehicle?
Brad Roberts |
Nov 21 2004, 01:49 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I'm trying to think of someone who can help you. I have had them installed on multiple vehicles in the past, but it has been a LONG time since I have messed with them (8-10 years)
Tell me what the "GEM" is ? Is it the neutral safety switch ? B |
WoMBaT |
Nov 21 2004, 01:55 PM
It's the Generic Electronic Module. I think I have the right thing. There is supposed to be a 26 pin plug to the left of the steering column. I have found this. This, several relays and the fuse box are all kind of one thing all put together. It is just that my wires by the manufacturer's wiring chart don't do what the manual for the remote starter installation says. One should be positive and then go negative as you unlock the door with the key. The other should be negative and then go positive as you lock the door with the remote. They are BOTH positive ALWAYS.
I'll just wrap it up under the dash and wait for their tech support to open up on monday. (IMG:style_emoticons/default/sad.gif) Not sure why my wife wanted the damn thing anyway. Too inconvienent to go out and start the car on these cold Kansas mornings I guess. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:33 PM |
