> 1975 - Tach - Turn Indicator Bulb, Gauge Turn Indicator does not work
moldygreg
post Apr 2 2013, 07:54 PM
Stay Golden
The turn indicator (on the VDO tach) does not work on my 1975 914.
I suspected the bulb was burn out. When I removed the bulb it was the 12V-1.2W (see attached) This is the style of bulb that illuminates the 'defrost' gauge near the shifter. In looking at the PET exploded diagram and PET shows the correct bulb should be 90063110290 (12V 2W bulb)
I'm wondering if the original owner got creative here. Do all of the VDO gauges use the same light bulbs? (IMG:style_emoticons/default/confused24.gif)
Many thanks!
914Sixer
post Apr 2 2013, 08:09 PM
Late cars use the small bulbs as you have found with small black holders Early cars (up 75) use the larger bulb with no holder. Yes, the defrost and the turnsignal bulb are the same. Some of the 74 cars have mix and match on the gauges.
moldygreg
post Apr 2 2013, 08:12 PM
Stay Golden
QUOTE(914Sixer @ Apr 2 2013, 07:09 PM) *
Thank you! Now I have to trace down why it's not illuminating!
Cheers.
Mblizzard
post Apr 2 2013, 08:31 PM
I have a similar problem with my 1975. But while the do flash, the dash indicators don't. But to add to the fun, everyonce in awhile one of the flash once and only once just to keep me guessing.
Let me know what you discover.
914Sixer
post Apr 2 2013, 08:42 PM
Mike,
Your problem sounds like a bad turn signal relay and or worn out contacts on the turn signal switch. You have to pull the wheel off to check copper contact.
- Lo-Fi Version Time is now: 16th June 2024 - 08:36 PM
