moldygreg |
Stay Golden ![]() ![]() Group: Members Posts: 136 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest ![]() ![]() |
First time these rockers have been off ever! Drilled out original rivets and then cleared out three ponds of dirt! Amazingly, rust free!
Anyway, the damn three cheesehead screws won't budge. Snapped one off and will have to drill out (another fun project forthcoming) Currently blasting and letting them soak 24 hours with penetrating lube from Tacoma screw http://www.tacomascrew.com/s.nl/it.A/id.61346/.f Questions: Is there a penetrating bolt busting lube that reigns supreme or is mine good enough? How long should I wait? Any other tips? I don't have access to a welder so I can't tack on a better bolt head to loosen unfortunately. I also have mapp gas, but the rocker panel seems like it's acting like a heat shield and I suspect isn't getting the bolt hot enough. (IMG:style_emoticons/default/smash.gif) |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,917 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
I use PB Blaster and/or Liquid Wrench, but any penetrating lube should work. For tough ones, I also drill and use an easy-out.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Aero Kroil works well. tacoma screw products or online. that you have to get the product to defy gravity doesn't help much. esp on the top of the threaded hole/tip of the screw so it can drain down.
k |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
twist 'em off if they won't budge after soaking. then install rivenuts where you need 'em.
moldygreg |
Thanks all! These little guys were stuck!!
Was 2 for 6. I soaked for 36 hours and then used mapp gas and locking vise grips. The dirt that came out was laughable! They've never been off before. Good tip on rivnuts. I end up drilling the stuck ones out and then tapping new 6mm 1.0 screw. ![]() |
Dasnowman |
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada ![]() |
Wurth Rust off ICE freezes small bolts and screws works great. If you have easy access to the head of bolt or screw I just use a zip cut and make a flat head on the top of the screw or bolt and loosen it off. |
Lo-Fi Version | Time is now: 31st July 2025 - 09:56 AM |
