? about Weltmeister Stabilizer bars, How much adjustability? |
groot |
Nov 23 2004, 09:35 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Can someone tell me what the minimum and maximum length of the lever arm is on the Weltmeister stabilizer bars? Is it the same on the front 19mm and 22mm bars?
Thanks. |
groot |
Nov 23 2004, 09:49 AM
An estimate is okay. I'm trying to figure out the range of adjustment they have for torsional rate.
Jeroen |
Nov 23 2004, 09:52 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Dunno about the Weltmeisters, but I can measure my Taretts when I get home tonight...
Aaron Cox |
Nov 23 2004, 10:20 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
QUOTE(Jeroen @ Nov 23 2004, 08:52 AM) Dunno about the Weltmeisters, but I can measure my Taretts when I get home tonight... spend the extra money on the tarett (IMG:style_emoticons/default/agree.gif) good stuff.... i think it has about 3" of arm adjustablitlty or more |
groot |
Nov 23 2004, 11:05 AM
I'm actually thinking I'll go with some NASCAR specials, but I'm interested in knowing what Weltmeister or Tarret think is appropriate for range of adjustment.
I'll probably have much more range, but I want to size my bars to include the low end of the Weltmeister/Tarret. The Tarret's sure look cool, but I don't know why they chose to cantilever the link to the stabilizer bar arm (IMG:style_emoticons/default/unsure.gif) It's not that big of a deal, but it just seems strange. |
groot |
Nov 23 2004, 11:09 AM
Thanks. The Tarret measurements will help. I'm particularly interested in the low end of the range (softest setting of the bar). Since my front geometry is different I should be able to get away with less bar.
Mueller |
Nov 23 2004, 12:32 PM
I cheated, copied this off of the SmartRacing Products site (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
groot |
Nov 23 2004, 01:13 PM
Jeroen |
Nov 23 2004, 01:32 PM
The Tarett arms measure 6cm (from the center of the bar) for the stiffest setting and 15.5cm for the softest
The bar itself is 100cm |
groot |
Nov 23 2004, 02:28 PM
And thanks again.
Lo-Fi Version | Time is now: 8th June 2024 - 08:31 AM |
