Electronic Dizzy Wiring |
ruddyboys |
May 7 2013, 09:08 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I am replacing my old worn Dizzy with a looks new electronic 009 dizzy. Problem is I do not have instructions on how to wire it so I don't fry it. It has a yellow and Black wire with BA009E on the side. Any help would be appreciated.
monkeyboy |
May 7 2013, 10:29 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I'd guess that Black is ground, likely wired to the negative of your coil.
But in all honesty, you should be asking the vendor you bought it from. |
ruddyboys |
May 7 2013, 10:32 AM
I got this as a gift a few years ago and my Brother doesn't remember were he ordered it from. I had it in the truck and can not find a box or the instructions.
monkeyboy |
May 7 2013, 11:02 AM
My guess would be black wire to the negative of your coil, yellow wire to the positive.
That is just a guess, and if it starts to smoke, I was wrong (IMG:style_emoticons/default/smile.gif) |
toolguy |
May 7 2013, 12:08 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
If it's a magnetic [ hall effect] pickup, it has to have a power source and a signal out to the coil. .
BA009E Centrifugal Advance Distributor w/Electronic Ignition $99.90 BA009E* has electronic ignition to replace points already factory installed. *BAOO9E requires use of coil with an internal resistor or an external ballast resistor must be used |
ruddyboys |
May 7 2013, 02:38 PM
My Brother thinks he purchased this at Mid America, I can not find anything Porsche, but I know they use to sell Porsche after market merchandise.
He says that is how it came, from distributor. Tooguy, not sure what you are saying (I am not an electrical guy). Everything I see about electronic 009 dizzys say to put the black wire to - on Coil and red on +. Is the Yellow supposed to be the Red?? If I remove the plastic cap under the roter, is there a way to see which wire could be + and - |
Lo-Fi Version | Time is now: 7th June 2024 - 01:36 AM |
