1.7 Manifold Pressure Sensor, Excellent condition, MPS |
brant |
May 7 2013, 09:17 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I have a couple of spare MPS for a 1.7 Djet system
Here is the first one. It has NO vacuum leak down and tests perfect it is very clean it has never been adjusted and retains the factory settings and seal it has never been opened and is still factory riveted. this is ready to bolt on $185 shipped in the continental US brant Attached thumbnail(s) |
Kaduku |
May 7 2013, 11:03 AM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Are these interchangeable with a 1.8 with a D-Jet?
brant |
May 7 2013, 11:22 AM
the 1.8 uses Ljet
the Djet MPS, can be tuned to run on any displacement, but there wasn't an MPS on Ljet (only if someone swapped out to Djet on a 1.8) |
Kaduku |
May 7 2013, 12:35 PM
the 1.8 uses Ljet the Djet MPS, can be tuned to run on any displacement, but there wasn't an MPS on Ljet (only if someone swapped out to Djet on a 1.8) Well I guess my car is a Frankenstein. I was told my 73 1.7 was swapped out with a 1.8 in the 90s, but the DJet was kept in there. |
brant |
May 7 2013, 01:13 PM
That is completely possible.
Djet can be bolted onto a 1.8 and work well its been done many times ideally, the MPS would be tuned for the slight bump in compression but the 1.7 and 1.8 are so close that it may not really need much tuning.... (maybe none?) geoff would know probably from his experience in first hand tuning MPS for different applications. I've had him tune 1.7 units with the wavetech for 2.0 motors all of the units should be using the same diaphram, its just the settings that are changed between the 2.0motors and the 1.7 motors. brant |
brant |
May 11 2013, 07:18 AM
bump
brant |
May 14 2013, 01:23 PM
bump
luskesq |
May 14 2013, 05:38 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Brant, I received one of the other ones from you last week. Although you claimed it wasn't as "nice" as the one you are showing here, it was very nice, zero vacuum leakage and electrically good. Thanks for the prompt and speedy shipment.
Keith |
brant |
May 15 2013, 10:10 AM
Brant, I received one of the other ones from you last week. Although you claimed it wasn't as "nice" as the one you are showing here, it was very nice, zero vacuum leakage and electrically good. Thanks for the prompt and speedy shipment. Keith Thanks Keith, I'm glad it arrived safe and sound |
brant |
May 22 2013, 01:42 PM
another bump
brant |
Jun 23 2013, 08:28 AM
bump
brant |
Jun 27 2013, 01:58 PM
no one is in need of a great 1.7MPS?
Lo-Fi Version | Time is now: 1st June 2024 - 08:15 AM |
