> Eagle GT V rated 195.65.15?, About to pull the trigger
jesiv
post May 14 2013, 09:38 PM
So i am looking to get Goodyear Eagle GT V rated 195.65.15 for my 1975 1.8 with stock Fuchs rims. Is this a bad choice for a daily driver?
Also, I am buying 5 tires for the spare. Should I buy six to have an extra pair? I have a boxster and rears wear two to one vs fronts. Thoughts...
Regards
James
Updated to reflect correct tire size
dlee6204
post May 14 2013, 10:01 PM
Howdy
I had the Eagle GTs on my car and thought they were a great tire. My car is a daily driver And I drove in all conditions. My only complaint is that they wear fairly quick. In my case, <20k miles
a914622
post May 14 2013, 10:32 PM
I have a set on my work car (2011 fusion). About 30k on them so far. Good all around tire. I drive about 35k a year. I have had them at jail speed for an extended lenth of time with no issues wet or dry.
jcl
Black22
post May 15 2013, 12:36 AM
I love mine! I have 205/60/15. Good in all conditions that a daily driver encounters, although I've never driven them on snow or ice. I also like the lip that saves your rims from curb rash...every tire should have it.
dlee6204
post May 15 2013, 04:56 AM
Howdy
QUOTE(Black22 @ May 15 2013, 02:36 AM) *
rhodyguy
post May 15 2013, 08:34 AM
the wife's car came shod with them. while others may like them they were horrible for our climate on a daily driver. prob better suited for a warm region. when a pt cruiser can break traction in the wet or cold they're useless. i found them extremely noisy at freeway speeds too. when they were spent, the duffus service rep explained to me how important it was to have the V rating due to the turbo. right...
Spoke
post May 15 2013, 09:37 AM
Jerry
QUOTE(jesiv @ May 14 2013, 11:38 PM) *
195.75.15
I would go with 205/50/15 or 195/60/15 for a lower profile look. May throw off your speedometer but the car will look much better IMO.
stugray
post May 15 2013, 01:21 PM
There is a reason that almost all highway patrol cruisers run Eagle GTs.....
That is one reason that you can get such a good tire at such a low cost (huge production volume).
I had them on my 914 in the 90s and loved them.
Stu
steuspeed
post May 15 2013, 03:06 PM
You mean 195-65-15 (IMG:style_emoticons/default/poke.gif) they don't make a 195-75-15.
My car came with Pirelli P6000 tires. The ride was a bit stiff, but cornered like on rails. I didn't think much of the tire until some jerk offs slashed them. Choices are limited in the 195-65-15, so I went for the Bridgestone RE960AS since it was the highest rated tire at the time on tirerack. The ratings on the P6000 were not so good, BUT if you look only at Porsche owners they liked them. Got those Bridgestones mounted and hated them from turn one. They were like marshmallows in comparison. Sold them after 500 miles on CL. The Eagle GT was next on my list, but I didn't go for them because of the weight 24lb vs 19lb. For a daily driver they may still be a good choice though. Instead I went for the Dunlop Direzza Star Spec Z1 195-55-15. TR only had a few left and now they are no longer available. The negatives are the car sits lower, more scraping, 200-300 more rpm hwy cruising, more shifting and speedo is off and still not as sharp turning as the P6000s. The positives are lots of grip, faster off the line, sits lower, better looks and better ride then the P6000s. Hope that helps out a little.
aircooledtechguy
post May 15 2013, 09:48 PM
The Aircooledtech Guy
I've been running 195-60-15 GTs sice a couple days befor leaving for WCR2013. I had my car up on my lift last week for a valve adjust and was surprised to be down to the wear bars on the inner treads. That's in 12 months and only 12K miles!!
Other than the fast wear, I have not had a problem with the performance in either wet or dry.
For the price ($53 each), I can't really bitch about the accelerated wear,. . . but I still will.
biosurfer1
post May 15 2013, 09:56 PM
Teener fo Life!
QUOTE(aircooledtechguy @ May 15 2013, 08:48 PM) *
How early did you leave for this year's WCR?!?! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif)
jesiv
post May 16 2013, 08:39 AM
Where did you get then for 53 they are ~80 on Tire Rack
Regards
James
Drums66
post May 16 2013, 01:44 PM
914 Rudiments
QUOTE(jesiv @ May 16 2013, 07:39 AM) *
Regards
James
...Often times(sears,costco,walmart)
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif)
442nd914s
post May 16 2013, 04:50 PM
I bought mine at tires.com (no affiliation). Here's what they look like (195/65R15)
Gt's vs oem Attached Image Attached ImageAttached ImageAttached Image
442nd914s
post May 16 2013, 04:57 PM
Not a great picture, but here they are installed. Btw, I bought 5 and put metal valve stems instead of rubberAttached Image
aircooledtechguy
post May 16 2013, 06:39 PM
QUOTE(biosurfer1 @ May 15 2013, 08:56 PM) *
I'm driving straight from WCR'12 to WCR'13. . . I'm still on my way. My car's a clapped out 1.8L ya know. . . (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving.gif)
aircooledtechguy
post May 16 2013, 06:43 PM
Regards
James
That was the price at my local Discount Tire. I don't know if they were on sale at the time. I never asked. I needed tires like yesterday and they had a set.
jesiv
post May 17 2013, 10:24 AM
Pulled the trigger 195/65/15 Eagles. Next week new tires, turbo tie rods, sway bar, front and rear alignment. Car should handle much better!!
steuspeed
post May 17 2013, 11:39 AM
I would be very interested to hear your comments on the tires once you try them out.
- Lo-Fi Version Time is now: 9th June 2026 - 01:34 AM
