Hangers for Monza muffler? |
PDXMike |
May 22 2013, 03:15 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
My '75 1.8L has a Monza (I think) muffler. There is a tab on the muffler that looks like it is meant for a hanger, but I don't see any corresponding mounting features on the bottom of my car. Is there something missing from my car? Do I need to fab up something for the underside of the car? Do I even need a muffler hanger in this set-up? It seems like a lot of weight hanging off the heat exchanger flanges.
ThePaintedMan |
May 22 2013, 03:24 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
My '75 1.8L has a Monza (I think) muffler. There is a tab on the muffler that looks like it is meant for a hanger, but I don't see any corresponding mounting features on the bottom of my car. Is there something missing from my car? Do I need to fab up something for the underside of the car? Do I even need a muffler hanger in this set-up? It seems like a lot of weight hanging off the heat exchanger flanges. The exhaust hanger should bolt to the exhaust/heat exchanger flange interface, and then to the back of the transmission. Its hard to tell in the picture, but it looks like you have that already. If not, do NOT try to run it or even have the muffler installed. You're right, all the weight on the heat exchangers alone is a good recipe for pulling exhaust studs out of the heads. I think the hanger should be sufficient, even with a Monza exhaust as long as everything is tight and in good shape. |
PDXMike |
May 22 2013, 03:28 PM
The exhaust hanger should bolt to the exhaust/heat exchanger flange interface, and then to the back of the transmission. Its hard to tell in the picture, but it looks like you have that already. If not, do NOT try to run it or even have the muffler installed. You're right, all the weight on the heat exchangers alone is a good recipe for pulling exhaust studs out of the heads. I think the hanger should be sufficient, even with a Monza exhaust as long as everything is tight and in good shape. OK, I've got the hanger at the back end of the heat exchangers. I was just curious if there is anything else. Your Monza doesn't have anything supporting it except the 6 bolts on the flanges? |
TheCabinetmaker |
May 22 2013, 03:59 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That is the way 914 mufflers are mounted. 6 bolts with two of them thru the bracket.
maf914 |
May 23 2013, 05:17 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I have a 76 914 which had the same stock exhaust system as the 75. I added a Monza system and ran it for about a year. The hanger arrangement was the same as your photos show, and worked fine. The sound, well, I ran it for a year and that was enough, I went back to stock. I then went the 2.0L SS heat exchanger conversion route with a Bursch muffler and was happy with that.
As shown Your hangers look good. |
PDXMike |
May 23 2013, 06:51 PM
I have a 76 914 which had the same stock exhaust system as the 75. I added a Monza system and ran it for about a year. The hanger arrangement was the same as your photos show, and worked fine. The sound, well, I ran it for a year and that was enough, I went back to stock. I then went the 2.0L SS heat exchanger conversion route with a Bursch muffler and was happy with that. As shown Your hangers look good. I'm not thrilled with the sound either. I'll leave it as it is for now and add HE and muffler upgrades to the to do list. Thanks everybody! |
JRust |
May 23 2013, 07:39 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I've got a grea set of SS 1.7/1.8 HE if you want to change things around some
Lo-Fi Version | Time is now: 1st June 2024 - 10:12 PM |
