| markb |
May 20 2003, 05:53 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Hi All! I'm in dire need of a replacement bushing for my left rear control arm. I can't seem to find a replacement part number. Can anybody point me in the right direction? (IMG:style_emoticons/default/unsure.gif)
| Brad Roberts |
May 20 2003, 06:08 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
You wont find one.
You have to convert the car over to Welt plastic/urethane bushings or replace the control arm with another worn out rubber impregnated rear control arm. Or.. step up and GO ROLLER baby. B |
| markb |
May 20 2003, 07:18 PM
Does that mean Mike M's fancy new bearings work for the rear? (IMG:style_emoticons/default/mellow.gif)
| Brad Roberts |
May 20 2003, 07:20 PM
He has a rear bearing kit. I just did ANOTHER install yesterday/today.
Smooth as silk. I'm pretty sure they will be added to every car I build from now on out. B |
| morgan |
May 21 2003, 06:39 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 28-March 03 From: milwaukee WI Member No.: 488 |
(IMG:style_emoticons/default/icon14.gif) how much does that ruun for front and back rollers
jm |
| 914werke |
May 21 2003, 12:52 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,574 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Brad, Mike, I am very intrigued with using the roller setup on my car but a comment I think Brad made on another thread about periodic dissasembly has me concerned. Living here in the PNW its often Freakin WET! (IMG:style_emoticons/default/confused24.gif) so maintenance is my issue?
Is it possible to tap the bushing "collar" for a zerk fitting so you could grease the assmb. when needed w/o removal and dissassembly? Or is it more an issue of grit contaminantion? |
| Qarl |
May 21 2003, 01:00 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I'm going roller too! Sent my check off to Mike (Mueller) today. Yipee!
There's a thread on the Pelican 911 forum about bronze bushings in case you're interested. http://forums.pelicanparts.com/showthread....ighlight=bronze Regards, |
| maf914 |
May 21 2003, 01:47 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
In the Grassroots Motorsport magazine 914 Project Car a couple of months ago they installed a front and rear roller bearing set and were happy with the results. The supplier was from the North-East, I think, and the total price was around $800. Has anyone looked into this option? Does Mike offer front and rear, or only rear? Price?
Mike |
| URY914 |
May 21 2003, 01:52 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,534 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
They used units from Shine Racing in Mass.
Mike makes f & r. |
| seanery |
May 21 2003, 02:18 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Mike offers both front & rear.
I've seen them and they are very nice! |
| Mueller |
May 21 2003, 02:54 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Hey Mark,
Sorry to take so long to get back to you....swamped right now, in fact I was working until 3:30 AM to finish a rear kit to send back East today. (he is running the Shine kit on front) Mine; Fronts: 400 Rears: 400 Thiers; Fronts: 485 Rears: 485 Discounts for multiple purchases (more than one car) rdauenhauer, Use in the wet should not be a problem if good quailty grease is used, in fact boat trailer wheel bearing grease would be ideal. The rears have an o-ring. The fronts use an o-ring and RTV for sealing, a zerk fitting could be installed, but it would require match drilling after assembly, not that hard, but I could draw it up to make it owner optional. As long as one does not directly steam wash or pressure wash the suspension points, the grease is not going to go anywhere. Mike |
| Brad Roberts |
May 21 2003, 07:10 PM
I pulled them apart to check them (street car after two years).. and report back on what I found (with NO seals or RTV used).. they where fine. Jeroen was with me.. I asked to carefully inspect the bearings for wear (so I would have a second set of eyes).. again they looked new.
After you ride in a car with them installed (and heavy springs/shocks) you will NEVER think about Welt bushings again. It smooths out the heaviest sprung cars out there.. the shocks actually work. The car will glide over pot holes/berms...LOL B |
| markb |
May 21 2003, 10:45 PM
Brad, you're making this way too hard to resist. (IMG:style_emoticons/default/blink.gif) Now I've gotta work them into the budget.... (IMG:style_emoticons/default/unsure.gif)
| Brad Roberts |
May 22 2003, 12:36 AM
Mikey... here you go:
I assembled "another" arm for the HPH race car tonight and shot some good pics. B |
| Brad Roberts |
ergwe
| Brad Roberts |
May 22 2003, 12:37 AM
qert
| Mueller |
May 22 2003, 10:37 AM
Hey Mark,
Does the 'Capt'n know? I'd imagine he'd be against these with a vengance (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/smile.gif) |
| Brad Roberts |
May 22 2003, 11:03 AM
Yep...and we should all take our braided brake lines off before they fail.
B |
| markb |
May 22 2003, 04:40 PM
To be honest, Mike, the Cap'n had never seen one go bad until my car. Figures mine would be the first. I just yanked an arm off one of my parts cars this morning, and next week when I'm at the shop I'll put it on. That should do me until I can scrape together the cash for a set of rollers from you. John hasn't said anything about not liking them, or the idea of them, so I'd say that's a good thing. (IMG:style_emoticons/default/wink.gif) I think they'll be great on Dad's Car, if I ever get the pans welded in. Gotta keep the Blue car running for now. At least I have on to drive. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 7th March 2026 - 12:55 AM |
