| Malpais82e |
Jun 6 2013, 09:22 AM
Newbie ![]() Group: Members Posts: 12 Joined: 4-June 13 From: Fort Collins Colorado Member No.: 15,968 Region Association: Rocky Mountains |
Thanks to this forum, I found I need a noid light. (now I know what one is).
The ads say "for Bosche PFI", port fuel injection. Will any noid light work? I realize I may have to use pins/adapters to hook one up. I read the D-jetronic is 3 volts; don't know if other injection systems are the same. A search hasn't help on specific lights. Thanks, Gordon |
| pcar916 |
Jun 6 2013, 09:40 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
A search hasn't help on specific lights. Many FLAPS rent/loan noid sets. One of them will likely work. My 993 injectors trigger at 3v, and I used a momentary 9v once to clear them of varnish. When I bought the engine in 1998 it had set up for two years. Good luck |
| stugray |
Jun 6 2013, 10:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You could use a bulb from a flashlight, they expect ~3Volts.
Or one 5cent LED with a 1k Resistor wired in series. A standard dash bulb would probably work as well, just might be hard to see. Stu |
| Cap'n Krusty |
Jun 6 2013, 10:36 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I'm pretty sure this one would be fine. Looks like the ones I've used over the years. I'm gonna replace the last one I had with either this one:
http://www.righttoolusa.com/p/Otc-7188-Bos...CFWKCQgodHFgAWw or this one: http://www.amazon.com/Lisle-27800-Universa...t/dp/B0002SR57Q (Probably the first one 'cause it's not likely I'll ever need one as fancy as the latter.) The Cap'n |
| Jon H. |
Jun 6 2013, 12:30 PM
Member ![]() ![]() Group: Members Posts: 242 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
I've used my test light with two stiff wires inserted into the plug, just make sure they don't touch each other.
Jon |
Lo-Fi Version | Time is now: 7th March 2026 - 04:05 AM |
