Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
I've been reading alot about removing the tar on the floor pans lately. My floors look great inside and out. Can't see any rust under the car. I would like to get by without scraping the tar off. Is there any way you can determine if there is rust under the tar without scraping it all up? It looks like a very labor intensive job. I try to avoid hard work whenever I can but I am finding that to be impossible when working on a 30 year old car.
Cheers, Elliot |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
Do you have a crystal ball? If so, tell Muller the right 6 numbers so he can buy that new car he wants.
Only way to know if there is rust under the tar is to take it up. I'm betting that there is. Think 99% of the ppls that have looked under theirs have found it. Heat gun, scraper, wire wheel and POR15....... |
Jenny |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None ![]() |
Seriously, it's a 2-3hr job to remove the tar if you have the interior stripped already, have a heat gun and a putty knife. I did it in a little over 2hrs, and I'm an amateur.
The hard work comes after that. The clean up. But it's really worth it if 1. you find out there's no rust in your floor pans, or 2. you find there is rust, but you caught it in time to repair it. Catch 22. Sorry. I'd vote foryou do it. Jen |
GWN7 |
See...the voice of one of the 99% (IMG:style_emoticons/default/smile.gif)
jridder |
Member ![]() ![]() Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 ![]() |
So what is the recommended treatment after taking the tar up, fixing any rust and painting with POR-15? Does anybody put tar or other sound deadening material back on? I suppose some padding and carpeting would help but the sound deadening material that is bonded to the panel does a better job because it lowers the natural frequency of the panel.
Jonathan |
Jenny |
I've started going at the rust areas with a wire bristle wheel attached to an electric drill. After that's done, yes, I believe I will be introduced to the art of POR-15-ing.
I heard Andy talking about sticking sound deadening material to the underside of the carpet. That way you can lift it up and check for water anytime you want. Sounds good to me! Jen |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
after the cleanup, make sure you put "Metal-Ready" on first, then POR-15 ...
Andy |
Jenny |
What's that??
Jen |
Elliot_Cannon |
Ah rats!!! I guess I knew what the answer was going to be to this question. I guess I am basically lazy and was hoping someone had a magical answer that would... Ah rats!!! OK so I need a heat gun. I guess my wifes hair drier wont do huh? How about a butane torch? How about I quit screwing around on the computer and get to work? Thanks to all for the good advice. (Now...where did I leave that putty knife?)
Cheers, Elliot |
SirAndy |
QUOTE(Jenny @ May 21 2003, 10:58 AM) What's that?? the stuff that turns your rust into something else (better?) ... Andy |
vortrex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None ![]() |
use a $5 plumbers torch, works great.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
QUOTE SirAndy Posted on May 21 2003, 11:50 AM -------------------------------------------------------------------------------- after the cleanup, make sure you put "Metal-Ready" on first, then POR-15 ... QUOTE QUOTE (Jenny @ May 21 2003, 10:58 AM) What's that?? POR-15 Metal Ready FAQ |
Elliot_Cannon |
So far so good! I used my butane torch and scraped up a 6x6 inch patch of tar. All I found under it so far is clean shiney metal!! Then I ran out of butane. The small patch I did though came off really easy. Looks like a Home Depot run for more butane.
Cheers, Elliot |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
12$ heat gun from Harbor freight... when you knock it over it doesnt light the car on fire.
I told Jenny to heat the tar just in front of her puddy knife as she scraped. Works like a charm. B |
Blynes |
Member ![]() ![]() Group: Members Posts: 68 Joined: 19-January 03 From: Savannah, GA Member No.: 169 ![]() |
Tar removal- this works if you can find one
called a blaster tool, made by Wurth has rotating metal prongs |
Lo-Fi Version | Time is now: 12th July 2025 - 03:05 PM |
