headlight motor, headlight wont go down |
chikenfajita |
Dec 1 2004, 11:10 PM
Newbie Group: Members Posts: 36 Joined: 28-November 04 From: san diego, CA Member No.: 3,183 |
hello, my left headlight wont go down, i can manually make it go down, turn the switch and it will go back up but not down, the right side one works perfectly, i know its not the relay because i switched them and it stil dosent work. any advice over what the problem might be, its really anoying, i dont look cool with one light up. (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/driving.gif)
Brad Roberts |
Dec 1 2004, 11:12 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
chikenfajita |
Dec 1 2004, 11:17 PM
its a 1970 914.
Brad Roberts |
Dec 1 2004, 11:24 PM
Have you done ANY work on the front of the car (in the trunk area) ?
One wire supplies voltage to both headlight motors and that wire comes from the headlight switch and then crosses over from the drivers side headlight to the passenger side headlight. So.. I'm betting the motor is bad if the passenger side works fine (it means voltage is present) B |
chikenfajita |
Dec 1 2004, 11:27 PM
but the motor goes up just fine. it just wont go down
Brad Roberts |
Dec 1 2004, 11:30 PM
Correct. I *think* they call it a switching diode... is bad in the motor.
Do a search on the site. Clay Perrine just posted a few days ago "How our headlight motors work" B |
chikenfajita |
Dec 1 2004, 11:37 PM
thanks man
ClayPerrine |
Dec 2 2004, 07:22 AM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Brad,
It's not a switching diode. There is a wiper contact in the motor. It can cause this. It acts like a switch on the motor to stop the motor when it opens. The relay just switches the power. The thread with the wiring diagram is in the classics threads folder. Chickenfajita... if you need help, just yell. I will be glad to give you advice on how to troubleshoot this. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:53 AM |
