sorry in advance..., stupid question. |
mattillac |
Dec 3 2004, 11:17 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
where the hell is the pcv valve on my 1975 2.0? i've replaced alot of stuff on the fi, hoses, etc. but i never noticed it, and my haynes manual doesn't show it. ok, let the hazing begin... (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/alfred.gif)
mattillac |
Dec 3 2004, 11:56 PM
nobody knows (IMG:style_emoticons/default/confused24.gif) i've stumped you all (IMG:style_emoticons/default/smoke.gif) or are you just above my lame thread (IMG:style_emoticons/default/pray.gif)
Dr Evil |
Dec 4 2004, 12:01 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
QUOTE are you just above my lame thread Yes, but I will answer anyway. It is in the oil fill housing. If it is on the 75 at all. There should be a port out of the side of the housing next to where the oil filler stalk sticks out. $10 for a new one from Porsche I hear (just the valve, not the whole housing). |
mattillac |
Dec 4 2004, 12:11 AM
i do have a "port" next to the oel filler neck, but it don't look like a pcv valve. it looks like a permanent part of the oel filler box assembly thingy(technical term).
Dr Evil |
Dec 4 2004, 12:20 AM
Infadel! You dare argue with me! Sorry, got ahead of myself. Is there a kneraled (lotta grooves going vertically, like a tooth paste cap) nut on it? If so that would indicate that you can remove it. But, if it aint broke dont breakit. I am not sure of the test for it, but I am pretty sure it includes blowing on it to see if too much air passes one way or another. It is your crank carse breather.
Dr Evil |
Dec 4 2004, 12:24 AM
Look at were the center hose is going in the picture in this thread posted by Andy. Iti si on the other side thatn I am used to, but it is what it is.
http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=21445 |
mattillac |
Dec 4 2004, 12:25 AM
no nut or anything on it. just a plain old tube. po had a FLAPS rubber heater hose going from it to the air box in what seemed to be the correct place.
mattillac |
Dec 4 2004, 12:26 AM
QUOTE(Dr Evil @ Dec 3 2004, 10:24 PM) Look at were the center hose is going in the picture in this thread posted by Andy. Iti si on the other side thatn I am used to, but it is what it is. http://www.914world.com/bbs2/index.php?act...=ST&f=2&t=21445 no sir. it goes vertically on the opposite side of the filler neck. |
Dr Evil |
Dec 4 2004, 12:28 AM
Why do you want to find and change it? Your year may not have one (IMG:style_emoticons/default/confused24.gif) It would have been that thing with the intimate parts on the inside. I am not sure where the hose to it is supposed to go. I am sure there is a picture some where.
mattillac |
Dec 4 2004, 12:31 AM
i was just curious. never saw it for all the times i've had my head burried in the hell hole. just wondering where i could find it. i didn't consider the fact that my car may not even have one.
Dr Evil |
Dec 4 2004, 12:34 AM
oh, good luck on your hunt. While your at it, try to find the radiator (IMG:style_emoticons/default/rolleyes.gif)
mattillac |
Dec 4 2004, 12:37 AM
thanks <_<
SirAndy |
Dec 4 2004, 12:41 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
not all oil-fillers are created equal!
the ones where the port goes directly into the filler-neck don't have a PCV. the ones where the port goes into the bottom square part of the filler either have a PCV inside the square part or (on early cars) just have a hollow space with some baffles inside to trap the oil ... (IMG:style_emoticons/default/cool.gif) Andy |
mattillac |
Dec 4 2004, 12:55 AM
so is the filler neck the only place where the pcv valve would be located on a 914?
Dr Evil |
Dec 4 2004, 12:58 AM
Ya know I'm only messin with ya.
mattillac |
Dec 4 2004, 01:01 AM
(IMG:style_emoticons/default/wacko.gif) i give up. my pcv valve can go 2 hell :finger2: hahahahahaha!
MarkV |
Dec 4 2004, 01:09 AM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
75 & 76 smog motors don't have a PCV valve. The oil filler is different, there is a baffle instead of a hole for a PCV valve.
mattillac |
Dec 4 2004, 01:14 AM
QUOTE(MarkV @ Dec 3 2004, 11:09 PM) 75 & 76 smog motors don't have a PCV valve. The oil filler is different, there is a baffle instead of a hole for a PCV valve. thanks! you da man! (IMG:style_emoticons/default/rocking nana.gif) |
Aaron Cox |
Dec 4 2004, 10:43 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
im still lookin for my radiator...you find yours? (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 04:04 AM |
