Converting 2.0 to Carbs, What all do I have to Change? |
Mblizzard |
Jul 23 2013, 08:35 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I know many will say don't do it. I am planning to make the conversion back to FI at some point. But for a short term solution I need to do this.
This engine is actually a 2056 with a stock cam. I know I am leaving some HP on the table with the use of the stock cam and carbs. I will be running Weber 44s with 28 or 32 vents. Engine has new 96 mm cylinders and the valve guides were all replaced when the valve job was done on the heads. New front and rear seals installed. I have the engine on the ground so i can get to everything. I have read some things to consider like blocking off the vent tubes on the heads. But I was wondering what else I need to address? I have read the stock dizzy will work but it needs the vacuum hooked up. Certainly there are other dizzy options. Any other suggestions on what is needed to get it going would be appreciated. |
'73-914kid |
Jul 23 2013, 09:41 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
I would recomend purchasing a mallory unilite distributor, and removing the vacuum advance altogether. Simple is good, and when you go back to fuel injection, you can sell it used for a decent chunk of money.
You also will need a breather box or tank for the oil filler vent. EMPI makes a rather cheap cast aluminum unit that works well. For a motor that will be eventually converted back to FI, I would just run the head vent hoses into the breather box. what else... 30mm vents would be a good balance between torque and high horsepower IMO, thats what I tuned my 2143 type IV to, and it runs beautifully. Thats pretty much it.. my recomendation to everyone is to invest in a good throttle linkage..it will make your life exponentially easier when tuning. |
'73-914kid |
Jul 23 2013, 09:42 PM
ThePaintedMan |
Jul 23 2013, 09:48 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Thats pretty much it.. my recomendation to everyone is to invest in a good throttle linkage..it will make your life exponentially easier when tuning. That's what I was going to say. If you've never used Chris Foley's cable linkage, now is probably the time. About an hour to set it all up the first time and you'll be able to keep everything synched from there on out much easier. And for only a few bucks more than one would spend on the Bellcrank style or Redline linkages. I'm still so grateful to FourBlades for setting me up with mine! |
CG-914 |
Jul 23 2013, 10:05 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I would recomend purchasing a mallory unilite distributor, and removing the vacuum advance altogether. Simple is good, and when you go back to fuel injection, you can sell it used for a decent chunk of money. You also will need a breather box or tank for the oil filler vent. EMPI makes a rather cheap cast aluminum unit that works well. For a motor that will be eventually converted back to FI, I would just run the head vent hoses into the breather box. what else... 30mm vents would be a good balance between torque and high horsepower IMO, thats what I tuned my 2143 type IV to, and it runs beautifully. Thats pretty much it.. my recomendation to everyone is to invest in a good throttle linkage..it will make your life exponentially easier when tuning. (IMG:style_emoticons/default/agree.gif) Also: You have to change the fuel pump to a 3 psi one and run everything on a 8mm supply line and no return line. Look for the article on conversion of fuel pump relay! FI supply line 9.5mm FI return line 8 mm Good time to use chris's Steel fuel lines! less fire hazard! |
Lo-Fi Version | Time is now: 7th June 2024 - 03:50 PM |
