914/6 large front remote oil tank installation, ..need pics and ideas how to run all the lines |
naro914 |
Jul 26 2013, 05:37 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
X Post, but this question is probably more appropriate over here instead of in Garage...
I need to install a bigger oil tank into Papa Smurf up front. Until now, we've been using a Patrick stock-ish /6 tank in the fender. But we had to modify it slightly so we lost a little capacity, and from what I'm learning, it might not have enough capacity anyway for a big engine with a BIG (GT3) oil pump. So, for all of you that have the round tanks mounted in the front trunk, can you post or email me more pictures of how you have the lines routed? how do you have the engine case vented? what is the flow of the system? what lines go where? how do you drain the tank? ONce I get this done, I'll be selling the tank we have. Its been modified, so I'll sell it for cheap - we had to cut into it a little when we installed the CFR raised suspension points set up...all welds are good and it works fine...was done by one of my buddies that is a fabricator for Earnhart Ganassi racing - and owns an AWESOME older 911 with a killer 3.4 engine.. He's done all the fab work on our cars and is a master at welding anything.... |
Matt Romanowski |
Jul 26 2013, 01:09 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
What does your front trunk look like now? Fuel cell or stock tank in there? I don't have any photos, but our oil tank is on the passenger side where the fuel tank used to be. Lines run through the cabin on the tunnel and also up the passenger heater ducts.
naro914 |
Jul 26 2013, 03:45 PM
stock tank. Oil cooler lines run through the heater ducts, so I can keep that. Where are you venting your engine case to?
yeahmag |
Jul 26 2013, 03:52 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
naro914 |
Jul 27 2013, 05:32 AM
where are you venting the engine to?
Matt Romanowski |
Jul 27 2013, 05:43 AM
Ours looks sort of like the picture above. Our engine has a line running up the back of the cage, down the A pillars, and to the front oil tank.
yeahmag |
Jul 27 2013, 12:12 PM
With regards to the motor, I run a -4, but I have welded a -10AN fitting to the breather chimney and run that to another catch can in the engine bay.
Lo-Fi Version | Time is now: 1st June 2024 - 10:48 PM |
