Flasher Relay |
Flasher Relay |
lsintampa |
Aug 5 2013, 01:16 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 914/4 2.0 FI
Yet another "aftermarket" part that fails to meet the task. I don't understand how vendors say this part is compatible with your car - when indeed it is not. Seems to be an ongoing challenge for me. Does anyone have a part number of a flasher relay that works correctly (doesn't buzz constantly - or have other erratic tendencies)? I don't care if it is Porsche part, or aftermarket for that matter.. just one that works as it should. |
JeffBowlsby |
Aug 5 2013, 01:49 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have a bag full of turnsignal/hazard flashers Len. You should make a list of things you need so I am not running the post office every other day HA!
But seriously, a relay should not buzz...maybe its some other issue? Have you cleaned all contacts, and grounds? checked the voltages at the relay base? Checked/cleaned replaced fuses? |
lsintampa |
Aug 5 2013, 02:02 PM
I have a bag full of turnsignal/hazard flashers Len. You should make a list of things you need so I am not running the post office every other day HA! But seriously, a relay should not buzz...maybe its some other issue? Have you cleaned all contacts, and grounds? checked the voltages at the relay base? Checked/cleaned replaced fuses? I don't have all the grounds connected for sure. My dash is out, as are all the instruments, so I'm sure there are harness grounds not attached. I would think (always a bad idea) that the flasher relay should work properly though. It is aftermarket - so maybe that's the deal. Wittrin or some such thing. It comes up as being for the 914 - in fact the part number is 914-618-303-11 IDK, maybe it's just me. But the thing buzzes with power on - clicks as you'd expect with blinkers and or four-ways on. Part is available from either AA or Big Bird and they both claim it is OK with the 914. This is sort of a re-post of one I posted a little while ago. Was directed to a thread on the Pelican board that talked about this issue, but I didn't see that it really matched my situation - or maybe it did and I didn't understand it. I'll hold it until I get more ducks in a row. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:56 AM |
