> taco plate leaks, any advice?
steuspeed
post Aug 19 2013, 03:45 PM
So I took out my taco plate and gave it a nice cleaning and fresh paint. I used a new gasket and new copper screw seals with proper torque. Any tips for stopping the leaks? Thread sealant maybe? (IMG:style_emoticons/default/confused24.gif)
TheCabinetmaker
post Aug 19 2013, 04:56 PM
I drive my car everyday
Did you remove the temp probe holder plate and replace the o ring?
worn
post Aug 19 2013, 04:58 PM
QUOTE(The Cabinetmaker @ Aug 19 2013, 02:56 PM) *
I put some curil t on the two screws. Helped a little. Still seems to just want to ooze as a full time gig.
Dave_Darling
post Aug 19 2013, 05:39 PM
914 Idiot
You didn't answer Curt's question:
QUOTE(The Cabinetmaker @ Aug 19 2013, 03:56 PM) *
--DD
steuspeed
post Aug 19 2013, 10:25 PM
I can't remember. I thought I replaced everything with new including a new temp sensor. I was being super anal since the car was new to me and I wanted to do things right. On my last oil change I took the taco plate out to look at the temp sensor since my new gauge is not working. The damn thing was dripping all over the place with the two screws out, so I just put it back together real fast.
gunny
post Aug 20 2013, 05:46 AM
QUOTE(steuspeed @ Aug 19 2013, 08:25 PM) *
I just did the same thing when replacing my temp sensor it leaked a lot.
To resolve I ordered a new O-ring, gasket and crush washers. I found that the old O-ring was compressed compared to the new one. PO had used some RTV on the O-ring so I cleaned all surfaces with a green scratch pad including case. installed parts dry (some like to lightly coat O-ring in oil). I also replaced the two bolts (bought at Home Depot). Now everthing is dry as a bone.
ChrisFoley
post Aug 20 2013, 07:26 AM
I am Tangerine Racing
Draganc had to replace his taco plate when he had a drip that wouldn't go away.
He measured it carefully and it was smaller than a good one - so the o-ring didn't fit tightly against the case.
There was no evidence of damage, it just didn't fit well enough anymore.
jaxdream
post Aug 20 2013, 07:39 AM
Is there possibly an over size o-ring one could get that would seal up better ??? As in larger diameter section , not overall larger diameter ??
Jack
ChrisFoley
post Aug 20 2013, 12:35 PM
QUOTE(jaxdream @ Aug 20 2013, 08:39 AM) *
Jack
That requires a custom o-ring, available from VW/Porsche and not anywhere else afaik.
I searched when we did the group buy.
barefoot
post Aug 20 2013, 12:59 PM
QUOTE(Racer Chris @ Aug 20 2013, 02:35 PM) *
Jack
If someone can measure the O-ring ID size and section width, I can look at the Parker catalog to see what might be a slight oversize.
Standard O-ring sizes are .070", .103", .139", .210" IIRC section size and they all come in a bewildering array of ID's. I would recommend Viton as it has a wide temperature range. Let me know and i may need some of my own and can buy a lot size.
Barefoot.
draganc
post Aug 20 2013, 08:50 PM
If you search my posts you will find pics and dimensions.
I bought a brand new plate from Porsche. I think it was $30 and the std. oring worked just fine.
DC
- Lo-Fi Version Time is now: 16th October 2026 - 12:08 AM
