Distributor recommendations |
Shindog1961 |
Aug 21 2013, 09:41 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
I need recommendations on a new distributor for a 1.7 original EFI rebuild.
Cap'n Krusty |
Aug 21 2013, 10:19 PM
Because the original distributor is an essential component of the D-jet system, only the original type will work. Using the same part number assures the mechanical and vacuum advance curves are correct for the engine. There are no available aftermarket units available, although I believe there have been efforts on the part of a couple of 914 enthusiasts to come up with an alternative to the stock distributor., in the form of crankshaft mounted DIS.
The Cap'n |
Shindog1961 |
Aug 21 2013, 10:34 PM
Because the original distributor is an essential component of the D-jet system, only the original type will work. Using the same part number assures the mechanical and vacuum advance curves are correct for the engine. There are no available aftermarket units available, although I believe there have been efforts on the part of a couple of 914 enthusiasts to come up with an alternative to the stock distributor., in the form of crankshaft mounted DIS. The Cap'n Thanks Cap'n |
JawjaPorsche |
Aug 22 2013, 02:06 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
SLITS |
Aug 22 2013, 11:22 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The 009 won't work with F.I. in the first place.
Second, it was designed for VW stationary engines and has a totally inappropriate advance curve. Thirdly, the stock dizzy with the proper advance curve will give you the maximum HP the engine was designed for AND the proper gas mileage. I should also add that this has been beat to death over the years and the best use of an 009 is a fishing line weight. |
luskesq |
Aug 22 2013, 11:57 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
There is a used on on EvilBay but not indication as to dist. # or whether the vac. adv. cannister is okay. Might be worth an inquiry.
http://www.ebay.com/itm/PORSCHE-914-DISTRI...b61&vxp=mtr On second thought, contact Bruce Stone (bdstone914). He likely has some and I'm sure others on the on the Board do as well. Keith |
SLITS |
Aug 22 2013, 01:54 PM
There is a used on on EvilBay but not indication as to dist. # or whether the vac. adv. cannister is okay. Might be worth an inquiry. http://www.ebay.com/itm/PORSCHE-914-DISTRI...b61&vxp=mtr On second thought, contact Bruce Stone (bdstone914). He likely has some and I'm sure others on the on the Board do as well. Keith Its a 0 231 174 005 which was replaced by 0 231 174 011 .... used on Porsche 914 2.0L engines |
tracks914 |
Aug 22 2013, 05:15 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Either way, put a Pertronix electronic conversion in it and never touch it again.
euro911 |
Aug 22 2013, 05:59 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Check to see if yours has any wobble and wear. If it appears to be OK, take it apart, noting where everything was originally (a camera comes in real handy here), clean everything up, re-lube and reassemble it.
Also, stick a new o-ring on the base. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:23 PM |
