> Aftermarket fuel pump, What are my best options?
saigon71
post Aug 25 2013, 03:55 PM
Car is a 74 2.0 D-Jet.
Put power to my original three port fuel pump today and it leaked like a sieve at the seam. All hose connections are good.
I would be fine switching to an aftermarket two port pump. I remember hearing about a Bosch pump on this site at NAPA for $31, so I did a search on 914world to find the link. Just checked NAPA and the same pump is now $186.
Found a "Hayg" on Ebay for $50. Ad says it will fit a 914. But it is ebay and a pump I never heard of.
Has anyone found a reasonable aftermarket replacement lately?
Thanks.
Bob
914itis
post Aug 25 2013, 04:15 PM
I have a barely used 2 port that I can part out with since I will be doing my six.
Pm me if interested for pics.
JawjaPorsche
post Aug 25 2013, 04:19 PM
GR Parts has Bosch for$156
http://www.gprparts.com/ShopByVehicle.epc?...ump&mode=PA
post Aug 25 2013, 06:05 PM
Slits has the Ford? number for the same pump. Bout $50. I bought one as a backup. I bought a Bosch from Jonathon for the one I have in my car. Bought a quality pump and a cheap Chinese backup for insurance. (IMG:style_emoticons/default/biggrin.gif)
saigon71
post Aug 26 2013, 05:43 AM
QUOTE(JawjaPorsche @ Aug 25 2013, 06:19 PM) *
Thanks for the responses. After sleeping on it, I decided to go with a brand new two port Bosch pump from GPR. Free shipping!
One less thing to worry about when bombing around in a 40 year old car. (IMG:style_emoticons/default/biggrin.gif)
How do I re-plumb the fuel hoses going from a three port pump to a two port pump?
JawjaPorsche
post Aug 26 2013, 05:49 AM
QUOTE(saigon71 @ Aug 26 2013, 07:43 AM) *
On the return line, there is a Y connection where the fuel went back into the pump and the other to fuel tank. Just discard the Y connection and run return line back to the tank. No return line to fuel pump since you only have two ports.
The new fuel pump will have a smaller diameter than the three port pump. You are going to have to make some modifications on the bracket. I used an old Bosch coil bracket holder.
You will also need a different fuel filter than the one needed for the three port. The in port is bigger than the out port. I got mine from NAPA. Part Number 3274.
hot_shoe914
post Aug 26 2013, 06:18 AM
on ramp passer
I bought a 2 port from the local FLAPS for about 47.00, I have had no trouble in the 2 years I have been running it.
Mblizzard
post Aug 26 2013, 07:04 AM
QUOTE(hot_shoe914 @ Aug 26 2013, 04:18 AM) *
Do you recall which FLAPS? Most just give you a blank stare when you ask for 914 parts.
I have a FI system for my 2.0 that I am missing the pump and breather for. Would like to get a fuel pump to see if the system works.
TheCabinetmaker
post Aug 26 2013, 11:51 AM
I drive my car everyday
NAPA part #N69133. Under 100 bucks at my local napa store.
JawjaPorsche
post Aug 26 2013, 12:41 PM
QUOTE(The Cabinetmaker @ Aug 26 2013, 01:51 PM) *
Wow! That is a great price! Thanks for letting us know! (IMG:style_emoticons/default/beerchug.gif)
SLITS
post Aug 26 2013, 01:12 PM
"This Utah shit is HARSH!"
This is what NAPA was selling:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1377544365.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1377544365.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1377544365.3.jpg)
TheCabinetmaker
post Aug 26 2013, 01:25 PM
Yep. Same as I have. I bought 2 before they raised the price.
Have you used one Ron?
Mblizzard
post Aug 26 2013, 01:53 PM
Looking at the NAPA pump are there any specs? It is a single line pump which would have to have the return routed back to the gas tank. Would that not be under some high pressure?
JawjaPorsche
post Aug 26 2013, 02:10 PM
QUOTE(Mblizzard @ Aug 26 2013, 03:53 PM) *
If you have FI, you have to have a line back to the fuel tank.
If you have a three port now, just discard the Y connector.
TheCabinetmaker
post Aug 26 2013, 02:14 PM
One line from tank to filter, then to pump, then to fuel rail. return line runs directly from other end of fuel rail and back to tank. The 3rd line at the pump is eliminated.
SLITS
post Aug 26 2013, 02:23 PM
QUOTE(The Cabinetmaker @ Aug 26 2013, 12:25 PM) *
Put one on 76-914 (Ken) car in Cedar City, UT on the way to RCC12. Worked fine but that wasn't the problem.
It's a dead ass ringer for the 2 port '75 - '76 914 Pump.
I don't have any 4 cylinders but I keep a spare just in case. When they first came out they were $32.00 ... don't know what the price is now. It's a Bosch pump and not Chinese made.
As far as specifications I haven't found any but it will provide sufficient pressure and volume for a D-Jet system (and probably an L-Jet too!) based on fuel pressure readings from Kens' car gauge.
F00E191622 comes up: New Bosch Fuel Pump #69133/F00E191662 Mercury/Ford/Lincoln/Fiat (1980-1991)
Category: Parts & Accessories:Car & Truck Parts:Air Intake & Fuel Delivery:Fuel Pumps
Interchange Part Number: E2182
Other Part Number: fe0303
Part Brand: Bosch
Manufacturer Part Number: 69133
Bosch ESI only says it is an "Electric Fuel Pump" without any indication of applications.
chad newton
post Aug 26 2013, 05:42 PM
What about a Holley red or blue pump with a regulator? I don't know if any of us put out that kind of power to need that flow but could that be an option? What psi do webers run at?
TheCabinetmaker
post Aug 26 2013, 06:01 PM
Holley makes a high pressure fuel injection pump?
chad newton
post Aug 26 2013, 06:16 PM
QUOTE(The Cabinetmaker @ Aug 26 2013, 05:01 PM) *
Probably, but I was thinking about the carborated ones. How much psi for the fuel injections?
Cap'n Krusty
post Aug 26 2013, 06:20 PM
Cap'n Krusty
Operating system pressure is 30PSI, more or less, and the pump needs to be capable of somewhat more than that. I don't recall the flow rate. It is NOT recommended that you use a higher pressure pump and regulate it down. This has, over the years, to be pretty commonly disastrous.
The Cap'n
- Lo-Fi Version Time is now: 1st August 2025 - 06:22 PM
