PMB rebuilt rear brake calipers... never used |
billh1963 |
Aug 26 2013, 05:57 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Up for sale is a pair of 914 rear race calipers. These do not have a handbrake and, unless you have a handbrake solution, these may not be for you. Here's some other good points:
1. They have the same piston size as the larger 914-6 rear calipers (38mm). 2. They have the same pad size as the larger 914-6 rear calipers. 3. They work on the lighter, sometimes mandated stock solid rotor (in most cases nothing more is needed). 4. The nose section is the same casting as the 914-6 rear caliper. 5. They retain proper bias with pistons and pad sizes to the larger 48mm pistons of the M-Caliper, A-Caliper, S-Caliper and Brembo front calipers. Don't bolt on early 914 front calipers on the rear of your 914. This gives you a heavy rear bias (because of the larger 42mm pistons) and that is VERY dangerous. These are the perfect solution $150 obo |
chad newton |
Aug 26 2013, 06:23 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Up for sale is a pair of 914 rear race calipers. These do not have a handbrake and, unless you have a handbrake solution, these may not be for you. Here's some other good points: 1. They have the same piston size as the larger 914-6 rear calipers (38mm). 2. They have the same pad size as the larger 914-6 rear calipers. 3. They work on the lighter, sometimes mandated stock solid rotor (in most cases nothing more is needed). 4. The nose section is the same casting as the 914-6 rear caliper. 5. They retain proper bias with pistons and pad sizes to the larger 48mm pistons of the M-Caliper, A-Caliper, S-Caliper and Brembo front calipers. Don't bolt on early 914 front calipers on the rear of your 914. This gives you a heavy rear bias (because of the larger 42mm pistons) and that is VERY dangerous. These are the perfect solution $150 obo Sent u a message. I want them. |
chad newton |
Aug 26 2013, 06:26 PM
I just want to make sure they will fit a vented 911 rotor.
billh1963 |
Aug 26 2013, 06:27 PM
I don't know..... someone smarter than me will need to chime in.....
914Sixer |
Aug 26 2013, 08:09 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I do not see a spacer block, so I would say no. They look like 69 911T calipers, they were non-vented.
John1180 |
Aug 26 2013, 09:59 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
billh1963 |
Aug 27 2013, 05:08 AM
I do not see a spacer block, so I would say no. They look like 69 911T calipers, they were non-vented. Per information I got from Eric you are correct. This is what he said: .............. There are spacers available for them but it would require buying a pair of later 911 rears to steal them from. At which point he should... buy some later 911 rears. These are calipers for 69 911's and 76 912E cars. The only two years with solid rotors. Great for a 914 because you never really "need" anything more than a solid rotor in the back and... They will have the proper bias for a 911 front caliper upgrade. |
shuie |
Aug 27 2013, 06:38 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
great deal either way, but am I the only person who is seeing the spacer in that pic?
Here is one of the 911 calipers I have for my rears with the spacer removed for non vented rotors. You can see the two halves with nothing in the middle on this one. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-2075-1377609148.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-2075-1377609148.2.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1377609149.3.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.googleusercontent.com-2075-1377607537.1.jpg) |
billh1963 |
Aug 27 2013, 09:30 AM
SPF to John1180
Lo-Fi Version | Time is now: 1st June 2024 - 04:16 AM |
