Up for sale is a pair of 914 rear race calipers. These do not have a handbrake and, unless you have a handbrake solution, these may not be for you. Here's some other good points:
1. They have the same piston size as the larger 914-6 rear calipers (38mm).
2. They have the same pad size as the larger 914-6 rear calipers.
3. They work on the lighter, sometimes mandated stock solid rotor (in most cases nothing more is needed).
4. The nose section is the same casting as the 914-6 rear caliper.
5. They retain proper bias with pistons and pad sizes to the larger 48mm pistons of the M-Caliper, A-Caliper, S-Caliper and Brembo front calipers.
Don't bolt on early 914 front calipers on the rear of your 914. This gives you a heavy rear bias (because of the larger 42mm pistons) and that is VERY dangerous. These are the perfect solution
$150 obo
