pictures of the inside of a longitudinal, to route my oil cooler lines |
mrbubblehead |
Sep 1 2013, 11:52 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
hi gang. does anyone have a picture of the inside of a longitudinal? i mainly want to see the front half. i would like to see how the 90 degree elbow for the heater duct is attached. i am planning on running my oil lines thru the heater duct. up one side of the car and back the other side. but i dont want to come up that 90. i would like to either replace it with a 45 degree bend and rotate 90 degrees so the line will pop out close to the floor, then route around the inner fender well and then enter the front longitudinal section to exit into the front trunk. or..... completely eliminate that that 90 degree bend and come out of the long at a more gradual angle.
i will make a removable cover similar to this picture that i found. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1378101172.1.jpg) any pictures will help. i dont want to do exploratory surgery. i want to be least invasive as possible. those of you useing the heater channel as a conduit for your oil lines, how did you do it? thanks for the pictures doug |
cary |
Sep 2 2013, 07:19 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Post #12 on short notice is the best I can do.
http://www.914world.com/bbs2/index.php?sho...187546&st=0 |
sixnotfour |
Sep 2 2013, 07:51 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached thumbnail(s) |
cwpeden |
Sep 2 2013, 09:40 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
The insulated heater tube fills up lots of it. See the size of the clips
mrbubblehead |
Sep 2 2013, 10:32 AM
ya, i see now.... but im still cant figure out how some guys are getting their oil lines thru there. unless they are cutting the long open and either eliminating the 90 or cutting a hole in the 90. (IMG:style_emoticons/default/confused24.gif) my idea of rolling that 90 down 90 degrees would be too much work.... back to square one. (IMG:style_emoticons/default/headbang.gif)
r_towle |
Sep 2 2013, 10:38 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Why re-invent the wheel.
Put them on the outside of the long, just under the sill. There is room there, and if you drill the brackets out, you even have built in hardware to hand the lines. They are easy to get to later on, and they are protected by the rocker cover. They, they are out of the way, and you don't need to open up the structural element of the car. rich |
Lo-Fi Version | Time is now: 8th June 2024 - 05:34 AM |
