Odometer Trip Reset, How do you remove it? |
e_artiles |
Sep 14 2013, 02:24 PM
Member Group: Members Posts: 76 Joined: 14-February 12 From: Corona, CA Member No.: 14,131 Region Association: Southern California |
Dave_Darling |
Sep 14 2013, 03:11 PM
I believe that black plastic part just sticks through the bottom of the dash. There might be a nut on the underside, but I thought it just pushed through.
There should be a knurled knob on the end of the cable, held on by a little set screw. That needs to be removed before you can pull the cable out. --DD |
HarveyH |
Sep 14 2013, 03:32 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
On the other side there is the knurled knob. Loosen or remove the small set screw holding the knob to the reset shaft and remove the knob. Use a spanner,
modified screwdriver or the tips of a pair of needlenose pliers to unscrew and remove the eustechon. Pull the cable out of the lip of the dashboard. Method 2: As you pull the instrument out of the instrument panel, you can also use a small screwdriver to pry the nylon locking ferrule out of the back of the speedometer and then pull the reset cable out of the instrument, leaving the cable attached to the dash panel. Harvey As usual, Dave was faster..... |
TheCabinetmaker |
Sep 14 2013, 03:34 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
IIRC, the cable just pushes into the back of the speedo. Should pull right out.
Lo-Fi Version | Time is now: 11th June 2024 - 12:29 AM |
