vacuum advance stuck?, can't get it to move by sucking on it |
turk22 |
Sep 15 2013, 11:03 AM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
(IMG:style_emoticons/default/dry.gif)
I'm in the process of installing the Pertronix ignition, but before I do, I wanted to A: confirm the advance was working B: regarding McMarks thread, make sure I didn't have interference with the little advance needle While removing the points, I see a little movement (very little) of the plate. But when hooking a hose up, and sucking on it, I'm able to get any movement at all. How freely should the plate move (how much vacuum is needed to get it to move? How much movement should there be in the plate? Is there a way to lubricate the plate, without dismantling the vacuum advance? (nervous enough just having removed the distributor) (IMG:style_emoticons/default/blink.gif) Thx, Turk |
timothy_nd28 |
Sep 15 2013, 11:23 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I removed the plate in mine last weekend. I'm glad that I did, it was actually pretty easy.
turk22 |
Sep 15 2013, 11:30 AM
what should be used to lubricate the plate? Lithium grease?
TheCabinetmaker |
Sep 15 2013, 11:49 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've read the "suck on it" thing. I have never been able to suck hard enough to make the advance move. It takes much more suction that I have. Can't imagine anyone who can.
turk22 |
Sep 15 2013, 11:52 AM
Black22 |
Sep 15 2013, 11:53 AM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
It should move pretty easy. A thick milkshake through a straw is more than enough pressure to move the advance plate.
914_teener |
Sep 15 2013, 11:55 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
That plate is jacked up, and needs to be cleaned.
The arm should easily move by suction. If not ....you need to rebuild it or replace the diaphragm canister. This will cause a vacuum leak. |
r_towle |
Sep 15 2013, 01:25 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pull the c clip off the arm, detach the arm, see of the plates move freely....probably not.
Btw, this is a whole lot easier if you just remove the clamp nut Ann washer, then pull the unit out, work on it on the bench. Remember which way it is positioned.....the bottom tooth can only fit on way, so just remember where it was facing for timing it to get it started before you use a timing gun. For grease, I use wheel bearing grease. Remove the plates, remove the little clip that goes around both plates, remove the little ball in there, don't lose it, don't shoot it across the room, move slowly and work on a towel or rag so that ball can't get away from you. Then clean the plates off, they do come apart once the clip is off, but it's probably a tight fit. Don't damage the copper wire, just lay them open and clean them Smear both mating surfaces with grease, then the ball. Put the clip back on and test to make sure they now move freely. Rich |
cwpeden |
Sep 15 2013, 01:45 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Pull the c clip off the arm, detach the arm, see of the plates move freely....probably not. Btw, this is a whole lot easier if you just remove the clamp nut Ann washer, then pull the unit out, work on it on the bench. Remember which way it is positioned.....the bottom tooth can only fit on way, so just remember where it was facing for timing it to get it started before you use a timing gun. For grease, I use wheel bearing grease. Remove the plates, remove the little clip that goes around both plates, remove the little ball in there, don't lose it, don't shoot it across the room, move slowly and work on a towel or rag so that ball can't get away from you. Then clean the plates off, they do come apart once the clip is off, but it's probably a tight fit. Don't damage the copper wire, just lay them open and clean them Smear both mating surfaces with grease, then the ball. Put the clip back on and test to make sure they now move freely. Rich And check this post for wear. Any type of corrosion means material is being removed. I had a friend's dist. that could not be timed and it was worn here. Even after checking the CHT (IMG:style_emoticons/default/biggrin.gif) |
luskesq |
Sep 15 2013, 03:04 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Pick up a vacuum pump, HF has them for about $20, attach to vac canister and pull 15-20#. it should hold if good and as you are pulling a vacuum you should see the arm moving the plate.
Keith |
turk22 |
Sep 15 2013, 03:37 PM
Thanks all.
I was able to clean and lube the advance plate and vacuum arm, and get the advance to move more easily. I installed everything and timed the engine and its running pretty well. The exception is its 'hunting' at idle, and I think this is a vacuum leak that I have to track down. (I have a new set of vacuum hoses on the way from AA). I'm still pretty sure that the distributor needs a rebuild, and I'll look into that. I'm gonna need to get the vacuum pump from HF and confirm the vacuum canister on the distrib is working correctly. One of the reasons I did this was I needed to get a rebuilt MPS installed (thanks Jeff B. for the rebuild) to cure the rich running I was experiencing at all times. I did that and I am really happy to have that rich running and fuel smell gone. Turk |
gifted914 |
Sep 15 2013, 04:05 PM
middleagecrisis Group: Members Posts: 30 Joined: 17-April 13 From: Australia / Brisbane Member No.: 15,778 Region Association: Australia and New Zealand |
(IMG:style_emoticons/default/dry.gif) I'm in the process of installing the Pertronix ignition, but before I do, I wanted to A: confirm the advance was working B: regarding McMarks thread, make sure I didn't have interference with the little advance needle While removing the points, I see a little movement (very little) of the plate. But when hooking a hose up, and sucking on it, I'm able to get any movement at all. How freely should the plate move (how much vacuum is needed to get it to move? How much movement should there be in the plate? Is there a way to lubricate the plate, without dismantling the vacuum advance? (nervous enough just having removed the distributor) (IMG:style_emoticons/default/blink.gif) Thx, Turk Sometimes life sucks ! and It will suck easily. (IMG:style_emoticons/default/bye1.gif) |
914_teener |
Sep 15 2013, 04:56 PM
Test the advance and retard can on the dizzy as mentioned.
It could be the source of your hunting idle.....leak. |
turk22 |
Sep 15 2013, 05:53 PM
Test the advance and retard can on the dizzy as mentioned. It could be the source of your hunting idle.....leak. Is it possible to rebuild the Advance can on the distrib? or are there replacement can's available for purchase? How likely is it to find a replacement for this model distributor? Seems unlikely (IMG:style_emoticons/default/dry.gif) |
r_towle |
Sep 15 2013, 06:36 PM
You don't need it.
Pull the hose off and cap the hose. Vacuum advance is to get it off idle faster into the advance curve, but it will run fine without the vacuum advance. All the way up till these cars, the mechanical advance was plenty. Rich |
luskesq |
Sep 15 2013, 09:56 PM
You don't need it. Pull the hose off and cap the hose. Vacuum advance is to get it off idle faster into the advance curve, but it will run fine without the vacuum advance. All the way up till these cars, the mechanical advance was plenty. Rich Yeah, it'll run okay if you don't mind mediocre accelleration. With the vacuum advance fuctioning properly I hit the gas and go. Without the vac advance functioning my car is a dog taking off. I'd always opt to have the vac advance (a working one). Shop around, used cannisters are out there. Might try Bruce Stone. Keith |
euro911 |
Sep 15 2013, 11:27 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Have you adjusted your valves yet? My wife's car would 'hunt for idle' even after I replaced all the vac hoses.
I found cylinder # 4 was adjusted too tight. I re-adjusted the valves to spec and the hunting stopped (IMG:style_emoticons/default/smile.gif) I should have done the valve adjustment first, but I was just being plain old lazy (I really don't like doing valve adjustments, plus I didn't have my lift at that time - just jack stands) (IMG:style_emoticons/default/dry.gif) |
r_towle |
Sep 16 2013, 05:44 AM
He is troubleshooting.
Pull the hose off the distributor and plug the line. See if it helps your Idle issue. Simple test, then you can decide if you need to find and replace the canister. Rich |
turk22 |
Sep 16 2013, 08:38 AM
Yep, I'll try plugging the hose, and see if that addresses the idle hunting. (That should be a sign that the can diaphragm is bad as well, huh?).
I have the valve adjust materials, and oil change stuff coming, hopefully in a few days from AA. I'll keep my eye out for a can, or even a full distrib. I found a couple of references to this place that rebuilds distributors: http://www.philbingroup.com/rebuilt/distributors.htm I may consider that as well... I still need to, after the valve adjustment, verify my timing and make sure its spot on... I'm wondering if the "27 BTDC" is still correct if the vacuum advance is not working correctly? Any other suggestions? |
turk22 |
Sep 16 2013, 08:52 AM
Lo-Fi Version | Time is now: 9th June 2024 - 08:14 PM |
