Shifting, 1St gear |
Razorbobsr |
Sep 19 2013, 01:29 PM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
I just replaced the bushing in my shifter and the one at the end nearest the tranny, I can get 2/3/4/5 but its a tight fit however I cant get 1st!!!!!!! What did I do wrong? I do get R gear. Bob
wndsrfr |
Sep 19 2013, 06:24 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I just replaced the bushing in my shifter and the one at the end nearest the tranny, I can get 2/3/4/5 but its a tight fit however I cant get 1st!!!!!!! What did I do wrong? I do get R gear. Bob PM Dr Evil for his 31 pages of notes....in there is a great tutorial about the shift pattern and how to get it centered properly...don't forget about having the clutch adjustment right first though. See if you can get first when you're rolling forward about 4mph--if that works then it's the clutch adjustment for sure. |
Bob L. |
Sep 19 2013, 07:39 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Tried adjusting my linkage last weekend and now have the same exact problem. I guess I'm not done yet. Keep adjusting till it's right. Dr evil's notes should get you through. |
Razorbobsr |
Sep 20 2013, 07:15 AM
I just replaced the bushing in my shifter and the one at the end nearest the tranny, I can get 2/3/4/5 but its a tight fit however I cant get 1st!!!!!!! What did I do wrong? I do get R gear. Bob PM Dr Evil for his 31 pages of notes....in there is a great tutorial about the shift pattern and how to get it centered properly...don't forget about having the clutch adjustment right first though. See if you can get first when you're rolling forward about 4mph--if that works then it's the clutch adjustment for sure. I think the clutch is ok, how do I find these notes. Bob |
Razorbobsr |
Sep 20 2013, 07:23 AM
Where do/how do I find these notes from the the good Dr. about setting up a shifter after changing the bushings. Bob
championgt1 |
Sep 20 2013, 07:34 AM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
PM Dr Evil. He will send you a copy.
jmalone |
Sep 20 2013, 08:12 AM
Member Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California |
PM Dr Evil. He will send you a copy. First adjust the clutch. As there is no synchro on 1st the clutch adjustment is critical there should be 3/4 to 1inch of free travel at the clutch pedal. Dr. Evil's notes can be accessed by using the search feature, try the Member Vender's forum or the Garage |
Razorbobsr |
Sep 20 2013, 09:43 AM
PM Dr Evil. He will send you a copy. First adjust the clutch. As there is no synchro on 1st the clutch adjustment is critical there should be 3/4 to 1inch of free travel at the clutch pedal. Dr. Evil's notes can be accessed by using the search feature, try the Member Vender's forum or the Garage Clutch adjustment is good. Thanks Bob |
rjames |
Sep 20 2013, 02:09 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Can you get into reverse? If not, you may just need to adjust your shifter so that you have more throw towards the left by doing the following:
Put the trans in neutral Clamp the shift rod with something to keep it moving (wrench/vicegrips) Loosen the bolt that that holds the shift rod to the shifter in the tunnel, Keep the shift rod from moving, and move the shifter just a bit to the right. Tighten bolt |
worn |
Sep 20 2013, 02:20 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
worn |
Sep 20 2013, 02:21 PM
Can you get into reverse? If not, you may just need to adjust your shifter so that you have more throw towards the left by doing the following: Put the trans in neutral Clamp the shift rod with something to keep it moving (wrench/vicegrips) Loosen the bolt that that holds the shift rod to the shifter in the tunnel, Keep the shift rod from moving, and move the shifter just a bit to the right. Tighten bolt (IMG:style_emoticons/default/agree.gif) |
Razorbobsr |
Sep 20 2013, 03:04 PM
Can you get into reverse? If not, you may just need to adjust your shifter so that you have more throw towards the left by doing the following: Put the trans in neutral Clamp the shift rod with something to keep it moving (wrench/vicegrips) Loosen the bolt that that holds the shift rod to the shifter in the tunnel, Keep the shift rod from moving, and move the shifter just a bit to the right. Tighten bolt Yes, I get reverse well. OK, will try that as well. Thanks Bob |
rhodyguy |
Sep 20 2013, 04:35 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
vice clamping the rear rod on both sides where it passes thru the engine support bar locks it well in the fore/aft plane
jimkelly |
Sep 20 2013, 05:00 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
the adjustment on a tail shift set up is at the rear of the tunnel rod.
http://www.autoatlanta.com/porsche-parts/h...;section=701-00 on the side shift it is right under shifter, at front of tunnel rod. (pictured) Attached image(s) |
76-914 |
Sep 20 2013, 05:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
very, very small adjustments inside the tunnel; if it's the shifter. have you tried shifting it by hand, with the shifter disconnected? Watch the travel of the ball on the side shift plate thru all the gears and see if it's the same.
Dave_Darling |
Sep 20 2013, 08:08 PM
Razorbobsr |
Sep 22 2013, 06:43 AM
Razorbobsr |
Sep 22 2013, 06:45 AM
very, very small adjustments inside the tunnel; if it's the shifter. have you tried shifting it by hand, with the shifter disconnected? Watch the travel of the ball on the side shift plate thru all the gears and see if it's the same. Shifting by hand? Do you mean at the tranny? No, I have not. Bob |
Razorbobsr |
Sep 22 2013, 06:47 AM
the adjustment on a tail shift set up is at the rear of the tunnel rod. http://www.autoatlanta.com/porsche-parts/h...;section=701-00 on the side shift it is right under shifter, at front of tunnel rod. (pictured) At the tranny end all I replaced was the big bushing, I have R 2/3/4/5 gear but not first. Bob |
jimkelly |
Sep 22 2013, 07:58 AM
have we established if you have a TS or SS trans ??
Lo-Fi Version | Time is now: 2nd June 2024 - 12:42 AM |
