> bleeding brakes, etc, (title revised)
jimkelly
post Sep 27 2013, 10:50 AM
Delaware USA
I am trying to bleed my bone dry brake system with a MOTIVE pressure system and a mix of long tube, but since they say you can't use SPEED BLEEDERS with MOTIVE, I want to make sure I am not chasing my tail.
I did bleed each corners twice so far and have some small amount of peddle, maybe 25% or so of normal.
the picture below is a new bleeder and one I pulled out of my jack standed car.
Black22
post Sep 27 2013, 11:00 AM
I'm no expert, but those don't look like Speed Bleeders to me.
stugray
post Sep 27 2013, 11:07 AM
You should be able to blow both ways through a normal bleeder, but only OUT on a speed bleeder.
They have little ball valves in them.
URY914
post Sep 27 2013, 11:26 AM
Did you google speedbleeders for a picture?
jimkelly
post Sep 27 2013, 11:35 AM
Delaware USA
I tried youtube.
found this in google images
but the bliow method sounds ok for CLEAN ones (IMG:style_emoticons/default/barf.gif)
looks like speed bleeders have a two angle head
wndsnd
You wanted a horse, but got a goat. Nobody wants a goat....
These are speed bleeders Jim,
I took them out cause I couldn't get them to work.
John
Can't get the blur out but you can see the end fitting.
jimkelly
post Sep 27 2013, 11:49 AM
Delaware USA
thanks for the pic : )
jimkelly
post Sep 27 2013, 11:55 AM
Delaware USA
think I will try the two person - old school style - next.
at least I have some fluid in the system and it is not leaking at every joint (IMG:style_emoticons/default/smile.gif)
this was my first concern.
getting the air out, my next concern.
shuie
post Sep 27 2013, 12:35 PM
I've been fighting with the same issue for the last 3 days. I had no idea you couldn't use the speedbleeders with the Motive. That's how I used to bleed the brakes on my 911. I thought it was about the only way to do it without an extra person. I guess Im going back to the standard bleeders screws.
Elliot Cannon
post Sep 27 2013, 12:42 PM
Group: Retired Members
I've used speed bleeders all the time. Mostly because I can't get anyone to sit in the car and "pump the peddle". (IMG:style_emoticons/default/av-943.gif) Whenever it's time to bleed my brakes, my Wife somehow finds out about it and disappears for awhile. (IMG:style_emoticons/default/laugh.gif) I just used them recently after my 5 lug conversion and installation of new brakes.
jimkelly
post Sep 27 2013, 12:49 PM
Delaware USA
I do not see why they can't be used together, unless, the speed bleeders, need more than the motive's 15-20 psi produces, to open??
the problem I am having now, is that I have some peddle resistance, not much, but using the motive, tons of fluid comes out but very little bubbles.
thus I will try the 2 person technique next.
jim
QUOTE(shuie @ Sep 27 2013, 11:35 AM) *
jimkelly
post Sep 27 2013, 12:51 PM
Delaware USA
oh, and, it seems all the bleeders I have, long and short, are standard - as I can blow thru them both ways - not so tasty.
if I had a set of speed bleeders, I would give them a try for sure.
I did replace the hodge podge of bleeders on my car with all short ones.
URY914
post Sep 27 2013, 12:53 PM
I bleed the rears by myself. Use a long stick and push the pedal.
andys
post Sep 27 2013, 01:31 PM
For a one-man operation, pressure bleeding or reverse bleeding works best. When you're done, come back the next day and do it again; amazing how much incidental air remains trapped.
Andys
SLITS
post Sep 27 2013, 01:54 PM
"This Utah shit is HARSH!"
I use a Hospital Aspirator (vacuum pump).
One thing is to bleed the MC. I crack the fittings and let them drip for a while. You can also bench bleed the MC.
The prop valve (when I had one) I would essentially do the same as the MC with the ass end of the car high in the air.
It's hard to get the air out of the system.
r_towle
post Sep 27 2013, 02:03 PM
Custom Member
bone dry system wont bleed unless you bench bleed the master...or do it like SLITS said...
The master has no fluid to pressurize yet.
rich
jimkelly
post Sep 27 2013, 02:21 PM
Delaware USA
I did crack the hard lines to the MC, but only for a minute or two.
I will do the slits trick, longer, to my master asap.
thanks
jim
r_towle
post Sep 27 2013, 02:24 PM
Custom Member
QUOTE(jimkelly @ Sep 27 2013, 04:21 PM) *
guess I will do longer.
thanks
jim
you should be able to do the fronts in minutes once the MC is filled up properly.
the rears just suck to do alone.
Rich
jimkelly
post Sep 27 2013, 02:31 PM
Delaware USA
to be certain - we are talking about cracking these two fittings and letting the drip for an hour or so?
thanks (IMG:style_emoticons/default/beerchug.gif)
shuie
post Sep 27 2013, 02:45 PM
yep, I've got the same issue. Lots of fluid and really no bubbles. I've tried gravity bleeding with one end of the car in the air. Tried the Archimedes' Principle trick with lines strung up in the air above the reservoir and bleeders open. Tried the plumbers putty trick around the bleeders to make sure they are not sucking air into the brake circuit when open. I get a decent pedal if I pump the brakes lightly after the circuit pressurized by the Motive. It's almost like air in the MC gets pushed out, but as soon as I depressurize the Motive I have no pedal again. I'll try the MC fitting drip trick next.
I've never been able to bench bleed a MC without spilling all of the brake fluid out of it on the install before getting the feed lines snapped in place. I have no idea how people are able to do that while crawling under the car. I've never had any issues bleeding brakes with the Motive & speedbleeders before.
- Lo-Fi Version Time is now: 12th August 2026 - 04:50 AM
