shelby/914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains ![]() ![]() |
I was sorting parts that came with a 914 I bought and found two fuel pumps. One is a new 0 580 464 032 which appears to be for a 3 series BMW based on research, but can't find a source to cross ref to other possible applications. Hoping for a 914 use. The other is a used 0 580 463 010, which I think is for a bus. Anyone know for sure, especially for the new one.
Thanks, Dan |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Some members posted this link earlier that said this was proper two prong fuel pump.
http://www.napaonline.com/Catalog/CatalogI...9133_0384479771 |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
0 580 464 032 crosses to a new number 0 580 464 070.
It fits Alpha, BMW(EFI), Ford Falcon, Holden & Jaguar. That said, they are all EFI cars and the flow and pressure will be more than sufficient for a D-Jet vehicle. It's basically the same as the 010 you have used, but the inlet/outlet could be different along with the electrical connection. No worries! If you are panicked, I can run it on Bosch ESI on Monday to get the exact applications the pump was made for, but I am 99.9% sure it will work on your 914. |
shelby/914 |
Thanks for the help, the NAPA site is down. Haven't pulled the old one yet, but it's getting real noisy. Having to turn the radio up pretty loud.
Dan |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Better check for blockage before the pump. Low fuel supply makes the pump noisy.
The Cap'n |
Lo-Fi Version | Time is now: 17th June 2024 - 05:13 AM |
