Getting the stink out, Interior |
boxsterfan |
Oct 8 2013, 09:22 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
74 2.0L.....
What can be done to get the grungy, moldy smell out of the interior? I assume that a lot of the smell is built up in the carpet and/or the padding inside the seats and backpads. |
mepstein |
Oct 8 2013, 09:30 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
ozone generator kills the smell.
Spoke |
Oct 8 2013, 09:34 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
'73-914kid |
Oct 8 2013, 09:35 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Part of that it the "old German car smell" but you might give a large box of baking soda a try. Roll the windows up, close off the air vents, and place the box, open, in the car. They even sell a box with a mesh screen specifically for deoderizing..
If it really is a bad smell, remove all the carpet, and clean it with a carpet cleaning solution, remove the seats, scrub them with a non-oil/silicone based vinyl cleaner (NO Armour ALL!!) Not sure one the particle board behind the door panels, and the back pad.. but I'd start with the carpet, and maybe try simple green on a rag on the floorboards underneath the carpet. I've been through all of this with my car..it smelled like wet dog.. It can be removed little by little.. |
boxsterfan |
Oct 8 2013, 09:40 PM
Part of that it the "old German car smell" but you might give a large box of baking soda a try. Roll the windows up, close off the air vents, and place the box, open, in the car. They even sell a box with a mesh screen specifically for deoderizing.. If it really is a bad smell, remove all the carpet, and clean it with a carpet cleaning solution, remove the seats, scrub them with a non-oil/silicone based vinyl cleaner (NO Armour ALL!!) Not sure one the particle board behind the door panels, and the back pad.. but I'd start with the carpet, and maybe try simple green on a rag on the floorboards underneath the carpet. I've been through all of this with my car..it smelled like wet dog.. It can be removed little by little.. Thanks. I think I'll start with some baking soda. What's a non-oil/silicone vinyl cleaner (brand)? I'll have to pull the backpad and see if it stinks. I guess owning a Porsche stinks. Woe is me... (IMG:style_emoticons/default/sunglasses.gif) |
Mike Bellis |
Oct 8 2013, 09:46 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
ozone generator kills the smell. What is an ozone generator? Like an anti-gravity or perpetual motion machine? It is an electronic device that creates ozone. The ozone in part will bond with a fragrance molecule and make it inert. Thus eliminating smell. There are some farmers that use the technology frequently... (IMG:style_emoticons/default/smoke.gif) |
'73-914kid |
Oct 8 2013, 10:09 PM
Aren't O^3 generators in the range of like $500? It would work perfectly though....hmm..
I've used the Einszett Plastic Vinyl deep cleaner with lots of success.. Einszett Products It's the best product I've found, and then any FLAPS should sell a basic carpet shampoo.. Should do well, and you'll probably be surprised how much crap is in the carpet.. |
mepstein |
Oct 8 2013, 10:28 PM
ozone generator kills the smell. What is an ozone generator? Like an anti-gravity or perpetual motion machine? It is an electronic device that creates ozone. The ozone in part will bond with a fragrance molecule and make it inert. Thus eliminating smell. There are some farmers that use the technology frequently... (IMG:style_emoticons/default/smoke.gif) I used it when I sold real estate to get rid of moldy basement, cigarette, animal smell. I still have one and have used it to get rid of moldy car smell very succesfully. My unit was ~$450 but there are smaller ones available for less. First step is to remove the interior from the car. Clean the inside of the car. I put all the carpet into my washing machine on gentle and layed flat with something pressing flat on top. Clean seats, door panels and backpad out of the car. Set in sun to dry. Make sure there are no mouse nests under dash (there were in mine and the car looked pristine). If you don't buy an ozone unit, try to rent one. they work great. Re- install all the upolstery in the car. Place the generator in the car with the windows cracked and let it run for a couple hours. Air out car. Repeat if needed. Gets into the foam and vinyl and nooks and cranies and kills the smell. |
bandjoey |
Oct 8 2013, 10:46 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Moth balls?
r_towle |
Oct 8 2013, 10:49 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pull out the carpets and pressure wash them,
Remove the seats and let them bake in the sunshine for a few days. Remove the backpad and clean it front and back. Rich |
rhodyguy |
Oct 9 2013, 07:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
for the vinyl try dr bronner's liquid soap. the peppermint version. after a vacuum when the interior is out wash the hard surfaces with it as well.
carpets. look for a company that does fine carpet cleaning. as in oriental style area rugs. take the whole set in. shouldn't be that expensive. surprising what comes out of a set that looks clean. no foul for some wear patina on 40 y.o. carpeting in my book. |
Mblizzard |
Oct 9 2013, 08:16 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
OK at the risk of opening up myself to a fire storm I am going to say this. There are a few ways to deal with smells, absorb them (baking soda), wash them out (any number of methods), cover them up (moth balls and spray treatments)' or degrade them (ozone).
When dealing with orders caused by organic materials degrading (food, mold, door panels, etc) it is rare that any one of the methods is completely effective when use alone. If you don't remove the food source of the bacteria or mold creating the odor then it will almost always return. The use of ozone is the most effective when used alone. It is a reactive compound that is harmful to molds and bacteria as well as reacting to degrade the gases that they emit. It is also harmful to rubber and vinyls but only with long term use. But if you have a moldy area that the ozone does not reach it will spread back through the car as the mold starts to grow again. So I would say eliminate any sources of moisture in the car (yea I know that is not really possible in a 914) remove and clean your interior. Treat it with ozone while removed. Treat the car with ozone with the interior out any you will have the best chance for success. |
boxsterfan |
Oct 9 2013, 12:22 PM
Jeffs9146 |
Oct 9 2013, 12:29 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
My car was littered with rat urin when I got it and it took me 3 months to get it all out! Now is smells clean and fresh!
I removed everything from the interior, motor, dash and gas tank areas. Then I pressure washed everything including the heater tubes with a mixture of water, bleach and 409. I then left the car out in the sun 89'+ for a few days to dry out! Once that was done I began the 6 conversion so it sat for another 4 months before being driven. All good now! (IMG:style_emoticons/default/piratenanner.gif) |
914forme |
Oct 9 2013, 01:49 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Rental places rent Ozone Generators for ~50 a day. Or you can get a small on for Evilbay for ~100. I have one of the EvilBay ones, works great. Though it might require a couple of rounds. Park the car outside in the sun, stick the generator, fire it up and let it run. BTW, you don't want to breath a lot of 03, so once done, open the doors and walk away from the car.
Mblizzard |
Oct 9 2013, 02:20 PM
Rental places rent Ozone Generators for ~50 a day. Or you can get a small on for Evilbay for ~100. I have one of the EvilBay ones, works great. Though it might require a couple of rounds. Park the car outside in the sun, stick the generator, fire it up and let it run. BTW, you don't want to breath a lot of 03, so once done, open the doors and walk away from the car. Very good point! I should have mentioned that. |
Elliot Cannon |
Oct 9 2013, 02:35 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
74 2.0L..... What can be done to get the grungy, moldy smell out of the interior? I assume that a lot of the smell is built up in the carpet and/or the padding inside the seats and backpads. Don't let SLITS ride in your car. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/happy11.gif) |
Chris H. |
Oct 9 2013, 06:03 PM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Setting the stinky stuff out in the direct sunlight can do a lot of good. Had a set of seats and door panels that were mint but had some mildew issues...a couple of days in the hot sun took most of the edge off. Then just a good cleaning and conditioning and they were all good.
Porschef |
Oct 9 2013, 06:12 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
I had another car that was owned by a smoker. While it's not the same stank, burning an entire scented candle worked very well. No noticeable tobaccy smell after, may work for you here.
boxsterfan |
Oct 13 2013, 07:13 PM
So, I got around to taking out the interior this week (save for the carpetson the side and under the console). I cleaned as much as I could with 409 cleaner and I also let the backpad, seats, front trunk carpet/plank, and arm rest sit in the sun for several hours each day. The floor mats are just too far gone if you ask me, so I'll be looking for a new set. Anyway, it certainly smells better in the car now.
I plan to take the door panels off next weekend and clean out in there too. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:56 PM |
