reverse light switch connector |
shuie |
Oct 30 2013, 07:33 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Does anyone sell or make the connectors for the reverse light switch on the trans. case? Are the pins for the switch a standard size? I thought I would be able to use some of the leftover pins from my engine wiring harness but those don't fit the switch. Whats the best way to do this? Do I need a different switch, cut up a donor harness?
TIA |
chads74 |
Oct 30 2013, 07:44 AM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
My car had connectors that looked like they were a standard one you could go buy at your local FLAPS and crimp onto the wires.
Dave_Darling |
Oct 30 2013, 08:58 AM
I haven't tried it, but it sure looks like standard "bullet" connectors would work.
--DD |
Cap'n Krusty |
Oct 30 2013, 09:05 AM
I haven't tried it, but it sure looks like standard "bullet" connectors would work. --DD I've seen them used, and I've tried to use them. They don't fit properly. I have a stash of them, and I think I know where they are in the barn .................. Maybe. The Cap'n |
mskala |
Oct 30 2013, 09:25 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Does anyone sell or make the connectors for the reverse light switch on the trans. case? Are the pins for the switch a standard size? I thought I would be able to use some of the leftover pins from my engine wiring harness but those don't fit the switch. Whats the best way to do this? Do I need a different switch, cut up a donor harness? TIA Are you saying you don't have the connectors? If you have them and the wiring is just bad/broken, they can be de-soldered and re-used. They look like the crimp bullet style pieces but they are hollow and have a hole at the end where the wire and solder comes through. De-solder, clean, re-solder. |
stugray |
Oct 30 2013, 11:24 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The bullet type crimp connectors work, but you have to open them up a small amount
zambezi |
Oct 30 2013, 12:14 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Shuie
I have a few of the solder on ends. The 356 uses the same type bullet terminals. The brit cars also use a bullet connector. I have some if you need some. jim |
shuie |
Oct 30 2013, 12:44 PM
Awesome. Thanks!
mcbrems |
Aug 22 2022, 11:31 AM
Ferdinand's first was Electric! Group: Members Posts: 46 Joined: 26-April 10 From: North San Diego County, CA Member No.: 11,660 Region Association: Southern California |
Just discovered the female side of the bullet connector works great if you use a pair of needle nose pliers to compress it a little by rolling it in on itself a tiny bit. That way, it maintains some outward spring to hold it in the plug. You’ll need to remove the plastic insulator sheath. A dab of dielectric grease to keep the elements out, and you’re good to go!
Cheers! |
GregAmy |
Aug 22 2022, 12:40 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I believe these will work:
https://belmetric.com/bullet-connector-5mm/ But I got a solder-on pair from JeffB, I don't know his source. |
Chris H. |
Aug 22 2022, 01:28 PM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
914e |
Aug 22 2022, 03:46 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I think it is part number 99965210210 they solder on.
Justinp71 |
Aug 22 2022, 09:48 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I just bought some of the large yellow bullet connectors and they fit perfectly. |
dr914@autoatlanta.com |
Aug 23 2022, 09:27 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
they are the old 356 type bullet connectors and are soldered on to the wire ends we always stock them along with the cover boot
Lo-Fi Version | Time is now: 12th June 2024 - 01:59 AM |
